 Post subject: sd2 partition signature not found
PostPosted: June 30th, 2008, 17:32
Ive replaced my laptops hd and this message come out while booting sd2 partition signature not found. What does this mean?
 Post subject: Re: sd2 partition signature not found
PostPosted: June 30th, 2008, 18:42
It might mean the BIOS can suspend to disk, but requires a special partition to do so. Then again, it's all a friggin guess without more details.
PostPosted: July 23rd, 2008, 7:18
youre right about suspend to disk , But how do I make the copy for that partition?
PostPosted: July 23rd, 2008, 10:28
You mean, how do you make that partition on your laptop? Simple, use the Acer utility. It doesn't matter if you have a Toshiba, Lenovo, Dell Gateway, Sony, or other laptop. The Acer utility will work for all. If you want better advice, try asking better questions.
If you want to copy your entire old HD to the new HD, Norton Ghost can probably copy the secret partition, but it might not work right. Best way is to use the utility for your specific lapto... I mean, the ACER utility.
Users browsing this forum: No registered users and 94 guests
