 Post subject: WD1200VE modules
PostPosted: August 22nd, 2008, 17:12
Good evening gurus,
I have a WD Scorpio VE drive that will not allow me to recover data. Donor drive matches for pc swap. I have attempted pc board, hotswap, module copying, and finally reverse DE after hotswapping PCB. I started reverse DE with the donor drive and stopped it, put donor drive on standby, and hotswapped. Started DE in reverse again, the drive stopped working and powered down. Motor is spinning. Heads are parked, move to center, park again and drive spins down. When attempting module copy, the 3rd module read "mdl request IO error" on donor drive. Do I need to get a donor that I can copy modules from or are scorpios just messed up?
Any help would be greatly appreciated.
 Post subject: Re: WD1200VE modules
PostPosted: August 23rd, 2008, 9:04
On first reach´s DRDY DSC?, if its that, when u send the read sector command u got "ABRT???
PostPosted: August 23rd, 2008, 9:26
It got to a ready state, DRDY and DSC. Yes, when I tried to copy the modules, the last one got an error and I got ABRT.
PostPosted: August 23rd, 2008, 11:35
all right u said, u could check SA , could u post us here the SA scan structure complete?
PostPosted: August 23rd, 2008, 17:22
Id: Crit lvl: Cyl:Sector:Size:Read:HDR:CS:Date:Vers.: Description
04: : -23:65535:0:Yes:Error:Ok:/WRONG/:... . :
00: : 0:65535:0:Yes:Error:Ok:/WRONG/:...|(small circle with line underneath) :
00: : 0:65535:0:Yes:Error:Ok:/WRONG/: :
(in red)
D6: : 0: 655:257:No : : : :
Hope that makes sense
Users browsing this forum: No registered users and 76 guests
