 Post subject: ATA Passwords
PostPosted: August 24th, 2008, 5:16
Hi there
I recently took over the workshop stock of a small IT company
in the stock was a bunch of 2.5" drives
various makes and models
Problem is:
The techie they had was testing the drives in a dell laptop that went and added ata passwords to all of them.
The fujitsu drives I have managed to write a program the will disable the ata passwords but I am stuck on the toshiba, WD, IBM and hitachi drives
is disabling the passwords on these others drives similar to the fuj..(replacing the SA module)
if so where can I get software for messing with the modules on the other drives
I realise the tools will be limited to certain makes and models but I will to take the chance as I have about 50-60 drives here.
Thanx alot
Tony
 Post subject: Re: ATA Passwords
PostPosted: August 24th, 2008, 5:27
Pc3000 or Salvation (cheaper)
PostPosted: August 24th, 2008, 5:48
Or maby if you don't want to buy any of those, there might be any pro's in the forum that might help you out for a smaller fee...were are you located?
Regards/ Bosse
http://www.rescue-it.se
PostPosted: August 24th, 2008, 11:28
Yes, for reworking of a single lot maybe outsourcing is the word!
PostPosted: August 25th, 2008, 2:58
OK to start I am located in South Africa
I am interested in getting a PC3000 (and probably will sooner than later)
to Spildit
Yes I am using the vendor specific ata commands
and yes quite similar to what you have posted except mine runes from an assembler/pascal coded program
I have run a few tests and on the drive I have it does not seem to be saving the passwords in plain text, I could just be missing it but I have not seen it.
I am assuming the were all locked on the same laptop(could be a really bad assumption on my part too)
I have not had much luck with the forum search, do you know of anywhere on the forum that might have vendor specific codes for other makes? also I am keen on getting info on SA modules for other drives
I can outsource this but I would prefer to do it inhouse. I have built a customized PC in which I have written all the software from the OS up to do data recovery on drives that are not physically damaged I have implemented various filesystems(fat,ntfs,ext2/3, reiser, cd+dvd etc..) written my own cd/dvd writeer libraries for storing data on dvd's when recovered etc.. I am trying to expand this system to include more advanced features (started with Fuji)
If I can get this app to anything semi decent I would like to release a DOS version (for use on Hiren bootcd or simialr) for the community to use should they have a need for it.
I know at the moment it's really weak and simple but that is what I am aiming to improve.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 67 guests
