 Post subject: A small suggestion to make this forum meaningful !
PostPosted: September 21st, 2008, 12:39
Hi All,
We all use this forum to post messages when we are facing a problem.
We check every now and then to see if there are any reply to our post(Solution).
At times, we PM the Experts too.
At times, we forget to post how we solved the problem, which suggestion helped to get the data out.
When we expect others to share their experience in resolving our problem, its our courtesy to share the solution here. It will definitely appreciate/encourage the person who helped you.
Lets start this culture from now onwards. When we end any Topic, the Owner of the topic should make two lines in Bold as the final post
1. Final Solution:xxxxxxxxxxxxxxx
2. Thanks to:xxxxxxxxxxxxxxxxxxx
Note: Pls correct me if i'm wrong anywhere.
Thanks,
RDS.
Users browsing this forum: Majestic-12 [Bot] and 82 guests
cron
