 Post subject: Seagate Barracuda 7200.10 +12V short circuit
PostPosted: October 20th, 2008, 6:49
Since a few weeks my PC would shut down/reboot randomly. This saturday the PC finally died, so diagnosis became suddenly a lot easier :lol: .
I traced the fault to a defective harddisk. I could measure that this harddisk short circuits the +12V line to ground. I removed the PCB (in ESD safe workshop) and found that the problem must be somewhere on the PCB.
I don`t plan on repairing the PCB itself, but I would like to replace it to get my data off the disc. I`ll buy a new disc of the same size for this purpose.
Befor I run to the shop: is it possible to replace the PCB and get my data off? Is same firmware version or P/N needed?
HD details:
Seagate Barracuda 7200.10 320GB, bought in june
ST3320620A
PN: 9BJ04G-307
firmware: 3.AAF
date code: 08415
site code: TK
 Post subject: Re: Seagate Barracuda 7200.10 +12V short circuit
PostPosted: October 20th, 2008, 9:40
The trouble was your power supply that finally fried the pcb, I bet. +12v with poor filtering, likely dried/leak caps. For the rest, search the forum.
PostPosted: October 20th, 2008, 9:48
It seems that people fail to search the forum for valid posts that may help. I have seen a similar post to this being made so many times. ITs like Deja Vu!! :lol:
PostPosted: October 20th, 2008, 9:56
its more like Groundhog Day.
PostPosted: October 20th, 2008, 10:54
People expect someone to answer their questions in full, without doing any research.
www.datarecoveryne.com
PostPosted: October 20th, 2008, 11:24
Well i didnt get where i am by waiting on solutions fmo other people, why should anyone else? 8)
PostPosted: October 20th, 2008, 16:01
cos, people can buy medicine from PHARMACY without PRESCRIPTION. people can select AIDS Medicine when he is suffering for FEVER. people can cut their own hair having CUTTER. people can do anything.
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: October 21st, 2008, 2:30
Actually, I did a search but that didn`t came up with the results I expected. I only found something about a short to ground in some diode.
Sometimes it`s hard to come up with the correct search words...
If this question comes up so many times and you guys are sick of answering it, why not put it in a FAQ in the data recovery and repair area?
PostPosted: October 21st, 2008, 2:36
A short to ground in some diode.... You were so close...
PostPosted: October 21st, 2008, 2:39
No comment.
Users browsing this forum: No registered users and 72 guests
