 Post subject: HITACHI 120 GB
PostPosted: October 17th, 2008, 10:37
Hi to all!
hd binds and turns the engine but it does not read nor model and nor fw...
DRSC DRDY ABR
Label in photo!
Thanks advance!
Нет ничего невозможного
 Post subject: Re: HITACHI 120 GB
PostPosted: October 17th, 2008, 11:49
Well, at least check the modules for starters.
PostPosted: October 17th, 2008, 11:55
check firmware. if firmware cannot be accessed, check nv ram, if nv ram ok, check pre amp.
PostPosted: October 17th, 2008, 12:25
Very common for head failure. Even when no clicking, heads can still be at fault. Can you access SA at all? Does table of modules show accesibility?
PostPosted: October 17th, 2008, 12:50
(very beginers idea: warning, can ignore) a long while back we had one that did same, (trys to remember if it spun or not) spun up but no read, heads had stuck on the ramp after a jolt. freed them up and all ok. they seem either: to fall of the BACK of the ramp, or to get stuck between platter and ramp.
I'll open the disk again and report when i'm in the lab.
PostPosted: October 17th, 2008, 16:12
if the heads are really bad, I mean completely broke open or cut the platters badly, these drives don't even move them...
PostPosted: October 17th, 2008, 23:20
Hy sempre if doesnt show u SA structure could be
Head 0 Problem
PostPosted: October 18th, 2008, 1:05
Does it make seeking noises?
PostPosted: October 21st, 2008, 9:17
Selected family......................... : HTS548
Model by ID............................. : <ID IS NOT READ>
NV-RAM reading........................................................ : Error
Initialization error
Error : Error switching to techno mode
UNIVERSAL UTILITY
HDD does not support set max LBA
HDD does not support S.M.A.R.T.
Write cache............................. : not supported
Soft reset ...
Ok
Determine rotational frequency
RPM..................................... : Fail to determinate
Bus test started (ports x2, x3, x4, x5)
Writing "00" to ports
Status.................................. : Ok
"Running set to one bit" test
Writing "FF" to ports
"Running set to zero bit" test
Errors not found
Sector buffer test
Ok
Write sector buffer error (ABR) 51 / 04
Soft reset ...
Ok
IRQ Test
Ok
PostPosted: October 21st, 2008, 9:18
UNIVERSAL UTILITY
Soft reset ...
Ok
Errors not found
Sector buffer test
Ok
Soft reset ...
Ok
IRQ Test
Ok
NV-RAM BAD??
PostPosted: October 21st, 2008, 16:58
U ARE USING THE WRONG UTIL. (at least) But the problem is probably head related.
as I already mentioned somewhere... I don't remember exactly.
PostPosted: October 21st, 2008, 18:25
Hi Sempre,
J9 - quite common failure, probably some head not working perfectly.
Mostly media not damaged.
Check heads and if they clean under microscope replace original heads back - works quite often.
If native heads don't work swap with donor.
For research, (if native heads clean) swap native heads into donor - works quite often.
Note : Assumes pcb is perfect.
Seldom see J9 wth fw or nvram problems - like seagate almost always heads.
I think these heads so finely small they just lose location or something like that.
PostPosted: October 27th, 2008, 18:41
Where do I begin to hook these drives up so that I can read drive data. I have read the noob's guide already... I just dunno where to start...
Thanks,
JR
PostPosted: October 27th, 2008, 18:54
The best option is to read it by heads in Data Extractor and then swap heads later if needed.
If you start reading sequentially or by files it will go clicking very soon.
PostPosted: October 28th, 2008, 20:28
Actually, I try to connect via USB and would not load. Cannot see in device manager or dir tree. I do a direct connection (laptop) and get BSOD device error.
What other ways can I connect?
PostPosted: October 28th, 2008, 21:01
Try using HDDscan or mhdd. you can find it on this website.
www.datarecoveryne.com
PostPosted: October 28th, 2008, 21:03
And.... do not post in every other topic :)
PostPosted: October 28th, 2008, 23:03
sempre wrote:
NV-RAM BAD??
No
delete the IBMOverride.ini and restart utility, use utility for IBM/Hitachi and select your model there, check SA
PostPosted: November 2nd, 2008, 0:39
Thanks for the replies so far...
will try not to dupe post... just anxious lolz :lol:
-JR
