 Post subject: Toshiba MK4021GAS - Head swap
PostPosted: November 12th, 2008, 9:18
Hello everybody.
I have a hard drive that comes up to ready state but while imaging it behaves very strange - shows a lot of CRC errors but jumps quickly throught them, and when I restart imaging it reads properly some of them and so on (each restart gives better result). The thing is that it goes very slow (about 5% a day) so to get full (or almost full) image I'd have to spend a month to complete.
I thought that this could be a head, so I got a drive of same model and manufacture country but after swapping it just knocks badly. I put heads back into original drives and both come up fine.
Now my question - is that a head problem, and if so why isn't it working? What are other requirements for head swap in TOSHIBA? Could that be faulty RAM chip?
Greetings,
yco.
 Post subject: Re: Toshiba MK4021GAS - Head swap
PostPosted: November 12th, 2008, 9:33
Probably bad motor/bearing.
PostPosted: November 12th, 2008, 9:55
Sounds me too.
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: November 12th, 2008, 10:52
Its bad motor. When the disk is repowered motor gets up to speed for very short while. You have 3 options.
1. Heat Bearing or Move Platters
2. Image for the next 6 months
3. Send to a pro
If data is important, option 3 should be your course of action.
ps.
A data recovery engineers best friend is a Toshiba :lol:
PostPosted: November 12th, 2008, 12:12
OK then, will give it a try.
I did platter swap quite few times with Toshibas and indeed they are very easy for that.
Will try it and post a feedback.
PostPosted: November 14th, 2008, 9:08
So I have news - swapped platters but still same thing. I replaced RAM chip and now the drive works perfectly. Taken full image now with not a single CRC error.
PostPosted: November 14th, 2008, 9:13
Thats the first case I have heard of involving faulty 'ram' chip. Maybe you got lucky with the disk initialization.
PostPosted: November 14th, 2008, 9:19
Me too, never heard of a faulty RAM chip causing this problem.
PostPosted: November 14th, 2008, 9:38
Please let us know where this RAM chip is located?
PostPosted: November 14th, 2008, 10:44
Hy hddguy RAM should be IC21 well im checking on a 60GB disk.
PostPosted: November 14th, 2008, 13:42
That is exactly IC21. In my case it is HYNIX HY57V161610DTC-8 16Mbit SDRAM chip.
