 Post subject: SAMSUNG HM160JC Harddrive problem
PostPosted: November 20th, 2008, 5:00
Hi everyone,
I have a problem with my 2.5" hard drive. Somethings happened and it's name has changed to "SAMCUNG HJ1&0JC". Now I want to bring it back. I tried many things but i failed. Can I renew firmware? May be resolve this name problem. Depend on this problem, Samsung disk utility programs did not work. So i thought i have to change disk name to "SAMSUNG HM160JC". May this will work. Where can i download the firmware files? Or what can I do else?
Thanks for your help....
 Post subject: Re: SAMSUNG HM160JC Harddrive problem
PostPosted: November 20th, 2008, 5:02
There is not a problem with your hard drive, I think the problem is with the connection. Is this an internal or external HDD?
PostPosted: November 20th, 2008, 5:21
hello,
i think it' not enough information from you about this case. we need more detail. e.g SA report
data recovery service[/b]
PostPosted: November 20th, 2008, 5:30
Do not mess about with the firmware.
Sounds like a bad connection somewhere, either between the PCB and the PC or on the PCB itself.
Sean
PostPosted: November 20th, 2008, 5:49
Wrong connectivity with the drive, either the Case.
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: November 20th, 2008, 6:21
Hi again,
This is an External hard drive, it's Lacie. So i take it out from case and plug it in to my laptop. I tried again, but program could not see SAMSUNG, it's recognize SAMCUNG :S ??. Only one program find the correct name and model, which is Hard Disk Low Level Format Tool 2.36 b1181. Now i am trying to format drive with this tools (over USB connection, externally). I thing it will finish Low level formatting. But, i will i do after that to use my HDD again?
PostPosted: November 20th, 2008, 6:30
If your 'tools' don't work, drive needs to be serviced but it's not worth the cost. P.s. Samsung does not release fw. , in any case I can fix either Rom or Sa if possible.
PostPosted: November 20th, 2008, 6:37
Sorry i meant, HDD Tools in Hiren's boot cd. But thanks for recommendations BlackST...
PostPosted: November 20th, 2008, 7:09
Thanks HDDGuru, yes, "Hard Disk Low Level Format Tool" solved all of my problems. Now it's working fine. Thanks guys...
Users browsing this forum: Nursalim and 85 guests
