 Post subject: MAXTOR HDD not spinning up.
PostPosted: November 16th, 2008, 4:35
Hi all. I've got a Maxtor HDD that's maybe a Maxtor DiamondMax Plus 45 drive, but can't be sure, because the sticker's off. What I know is the drive's capacity - 20GB and the PCB reads NEBULA 301334101.
The problem:
Suddenly the drive stopped working and would not spin up at all.
Could this be solved by replacing the PCB?
I'm from Bulgaria, so sorry about my English...
 Post subject: Re: MAXTOR HDD not spinning up.
PostPosted: November 16th, 2008, 4:49
Post a "clear" picture of the pcb.
PostPosted: November 16th, 2008, 5:00
Not common... Will be difficult to find a suitable pcb, I think.
PostPosted: November 16th, 2008, 5:07
Ok. Here it is:
PostPosted: November 16th, 2008, 6:39
Yep not very common but you can buy it from here :idea:
http://www.firmwarefinder.com/Search/pa ... id=1054094
PostPosted: November 16th, 2008, 6:52
I have a drive in my stock.
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: November 16th, 2008, 7:05
Write me a PM if you can send me just the PCB.
PostPosted: November 17th, 2008, 7:42
Any advice on matching PCBs? For example a 10GB Maxtor DiamondMax?
PostPosted: November 19th, 2008, 2:23
I have this PCB in stock PM me if required .
PostPosted: November 20th, 2008, 5:50
I've put a PCB from a 10GB Maxtor that fits in well but has a different main chip.
The drive is now spinning well, but heads produce regular clicks. At least I know the motor is OK.
Maybe a PCB replacement will fix it up well?!
PostPosted: November 20th, 2008, 5:59
If you can, check the 3.3V regulator!
In this family sometimes it gets bad.
Anyway, my little brother's girlfriend will come to me soon, from Bulgaria, so if you want, i can take a look to the PCB... :D
Regards,
Janos
PostPosted: November 20th, 2008, 6:07
Hi, thanks for the tip!!! I was wondering if it can be the problem.
I guess you mean the component that's a SOT223?
Looks like this:
I've got the same spare part in stock. Will try to replace it.
Cheers!
PostPosted: November 21st, 2008, 5:50
I've replaced the voltage regulator but nothing changed!
The drive looks completely "dead", not spinning and chips stay cold...
Meanwhile, I found this:
http://www.ihdd.ru/forum/maxtor-32049h2-nebula-vt3413.html?highlight=nebula - the guy solved the same problem by replacing the main chip...
PostPosted: November 21st, 2008, 6:18
At this point, could be anything....
The Eprom, the VCD, some parts in the main power line....
Need to measure one pro, to determine the problem.
Janos
PostPosted: November 21st, 2008, 17:45
Also could be the motor controller check that as well .
PostPosted: November 21st, 2008, 17:55
did u put a PCB on the drive from a different family?
If it was from a different family, don't expect anything more than clicking... these experiments are dangerous. If U need the data and don't have PCB for it, there are some DR firms nearby for sure. Or ask BGMan, he is from Bulgaria too.
could U post a picture of that board?
PostPosted: November 25th, 2008, 8:31
The PCB from the 10GB drive was definitely from a different family. Just wanted to check if the motor and the wires from it are all OK. Seems they are...
There is a picture of the board in one of the above posts.
PostPosted: November 26th, 2008, 10:01
Look for a donor PCB with C4DLA marked on it. If still clicks then do a rom swap.
or tests the components of the original pcb using multimeter.
PostPosted: November 26th, 2008, 10:04
A ROM swap? If clicks after replacing compatible PCB likely heads are damaged
PostPosted: November 26th, 2008, 12:38
He used a PCB from a different family, so it is not very surprising it clicked :)
Anyway, this thread can be terminated this way:
if U want to get quick access to your data, you have to pay the services of a pro, I suppose each one of us working in this field should lay such drive somewhere in our drawers, so it will not be a problem...
If U want inexpensive solution, try to dig up this board on the web, there's nothing more we can do here to support U I think, sorry.
Users browsing this forum: Google [Bot], skinbob and 39 guests
