 Post subject: seagate ata harddrive stops working
PostPosted: December 15th, 2008, 21:33
hi every body,my segate ATA harddisk stops working suddenly wen i am doing something.It will boot up wen i restarts the computer.but after some time it will go dead again.i tried replacing the power cord and ide cable.but no use the problem is still there.please reply
 Post subject: Re: seagate ata harddrive stops working
PostPosted: December 15th, 2008, 22:13
Insufficient information.
Probably bad sectors or power supply. The data can be recovered. Immediately copy any data about which you care to another disk. If that is no longer possible, you probably need professional help.
PostPosted: December 15th, 2008, 22:35
Could be bad sectors. Is the data important?
PostPosted: December 16th, 2008, 5:11
information is not enough. seek pro
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: December 16th, 2008, 5:21
Maybe there is one or more components on the PCB which overheat causing PCB to malfuinction?
Best course of action is to send to a professional for a more accurate diagnostic.
PostPosted: December 16th, 2008, 20:52
agreen with Wiseleo,do you want to want to you pay more and more for data recovery? back up immediately if you don't want. you can check what problem after backup.
data recovery service[/b]
PostPosted: December 24th, 2008, 10:47
thanks guys thnx 4 th replys.but actually the problem was with my motherboard.i changed the whole system.thank u guys
Users browsing this forum: Google [Bot] and 55 guests
