 Post subject: Advice on possible faulty Raptors
PostPosted: January 10th, 2009, 7:46
Hi, I wonder if someone could offer me some advice? This is my first post, so please excuse me if I haven't provided all the needed info.
I have 2 x WD740GD Raptor drives, and have recently been having some problems with them. (mainly corrupt Windows boot files so that XP won't fully load)
They were originally in a RAID 1 array but I imaged them, broke the mirror, and tried using each on its own as a boot drive.
They are both still under warranty but the WD Diagnostics tool passes both as OK. I've used MHDD to check both disks and the Smart logs are below. I don't want to return them to WD and then be charged because they say that they aren't faulty, so would be grateful for some advice on interpreting the results.
HDD: WDC WD740GD-50FLC0; FW: 33.08F33; SN: WD-WMAKE1956024
            Name                        Val Worst Raw
Att #   1 : Read error rate           : 200  200  0
Att #   3 : Spin up time              : 121  121  4458
Att #   4 : Number of spin-up times   :  98   98  2666
Att #   5 : Reallocated sectors count : 200  200  0
Att #   7 : Seek error rate           : 200  200  0
Att #   9 : Power-on time             :  86   86  10777
Att #  10 : Spin-up retries           : 100  100  0
Att #  11 : Calibration retries       : 100  100  0
Att #  12 : Start/stop count          :  98   98  2640
Att # 194 : HDA Temperature           : 115  104  35
Att # 196 : Reallocate event count    : 200  200  0
Att # 197 : Current pending sectors   : 200  200  0
Att # 198 : Offline scan UNC sectors  : 200  200  0
Att # 199 : Ultra ATA CRC Error Rate  : 200  253  15884
Att # 200 : Write error rate          : 200  179  0
HDD: WDC WD740GD-00FLA1; FW: 27.08D27; SN: WD-WMAKE1661867
            Name                        Val Worst Raw
Att #   1 : Read error rate           : 200  173  0
Att #   3 : Spin up time              : 114  114  4816
Att #   4 : Number of spin-up times   :  98   98  2911
Att #   5 : Reallocated sectors count : 199  199  1
Att #   9 : Power-on time             :  82   82  13158
Att #  12 : Start/stop count          :  98   98  2852
Att # 194 : HDA Temperature           : 117  106  33
Att # 196 : Reallocate event count    : 199  199  1
Att # 197 : Current pending sectors   : 200  199  1
Att # 198 : Offline scan UNC sectors  : 200  199  1
Based on my limited understanding of the numbers, the only thing that stands out is the CRC errors on the first drive. I have replaced the cables on both just to be sure.
I also ran a Scan using MHDD, and the second drive showed Warnings on 2 sectors, along with quite a few sectors that had high seek times compared with the first drive.
50 ERR INDX CORR DREQ DRSC WRFT DRDY BUSY        AMNF T0NF ABRT IDNF UNCR BBK 00
[WDC WD740GD-00FLA1    ] [  145,226,112] [  145,226,111] [  EST:   **:**:**  ]
°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°±°°°°°°°°°°°°°°°°°°°°°°°°°°°  ACT [123945 kb/s]
°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°° ° <3ms  : 560091
±°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°° ± <10ms : 7196
°°°±°²°°°±°°°°°°°°°°°°°°°°°°±°°°°°°°°°°°°°°°°°°°°°°°°°°°°°° ² <50ms : 2226
°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°±°°° Û <150ms:
°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°° Û <500ms: 1
°°°°°°°°°°°°°°°°°°°°°°°°±°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°° Û >500ms: 1
°°°°°°°°°°°°°°°°°°°°°°°°°²°°°°°°°°°°°°°°°°°°°°°°°°°±°°°°°°° ? TIME :
°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°° x UNC  :
°°°°°°°°°°°°°°°°°°°°±°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°° ! ABRT :
°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°±°°°°°°°°°° S IDNF :
°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°±°²°°°°°°°°°°°°° A AMNF :
°°°°°°°°°°°°°°°°±°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°° 0 T0NF :
°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°±°°°°°°°°°°°°°° * BBK  :
°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°° [100.0% ]  [100.0% ]
°°°°°°°°°°°°±°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°° Warning: 134217736
°°°°°°²°°°±°°°°°°°°°°°°°°°°°°°°°°°°°°°°°Û²°°Û°°             Warning: 145225560
Is there anything else that stands out from the above, or are there other checks I can run? Do you think these drives are faulty or is there something I can do to repair or improve them?
Thanks in advance.
 Post subject: Re: Advice on possible faulty Raptors
PostPosted: January 10th, 2009, 9:17
Your only problem is, the WD-WMAKE1661867 have one unreadable sector, wich can be corrected by write or will be re-allocated on spare space.
This drive will not pass the long read test in the WD diags...
Anyway these drives looks good, not need to replace.
Regards,
Janos
PostPosted: January 11th, 2009, 13:31
Thanks. Is it worth zero'ing the disk and reformatting? Would that make any difference?
There's no useful data on it at present.
PostPosted: January 11th, 2009, 13:58
yes, maybe will be OK again.
Anyway, i always suggest to my customers, replace all hdd wich older than 2 year, independently the condition...
Regards,
Janos
PostPosted: January 12th, 2009, 19:03
That's probably good advice, and ordinarily I'd replace the Raptors, but I'm thinking about changing PC soon.
I don't worry too much about losing my OS drive as it's fairly easy to rebuild, either from an image or from scratch. I have separate drives for data, and back those up - and the backup drives don't get used for anything else, so will hopefully last a while.
Anyway, thanks for the advice, Janos. Much appreciated.
John
PostPosted: January 12th, 2009, 19:19
your welcome ;)
Users browsing this forum: Google [Bot] and 58 guests
