please help
January 31st, 2009, 4:27
I have a WDC WD 800BB-53 DKAO.
I used AVG free virus scan and it put two system 32 files from this device in the vault.
After this I had to reinstall windows on my computer.
When I plug in my hdd into my usb, I get a message that my hdd is plugged in.
When I go to my computer, there is no sign of my hdd.
In the device manager, my hdd is there. It says that this device is working properly.
But there is no way I can open my hdd.
I hope someone here can help me.
Greetings Hetty.
Re: please help
January 31st, 2009, 5:42
Your drive is still infected. You'd better scan with anti virus once again to make sure the system is clean. And, yes, you must also fix the registry.
Re: please help
January 31st, 2009, 9:57
I tried to scan it again, but it doesn't mention the hdd in the antivirusprogram as well. If I want to scan special drives, I can't find my hdd.
You can only see it is there in the device manager, but in no other place. I could open it before I scanned it, the time before AVG put it in the vault.
As I said, after this I recovered my whole system and than I plugged in my hdd and there seems no sign of it anymore, except in the device manager.
Re: please help
January 31st, 2009, 15:17
Your data is probably fine, but you need help of a computer consultant. At least they should be cheaper than a data recovery expert.
You also may want to read this: http://www.cert.org/blogs/vuls/2008/04/ ... torun.html how to disable the autorun.inf vector of infection.
Consider going to http://www.drweb.com and downloading/running the CureIT tool as well.
Re: please help
February 1st, 2009, 3:44
It seems your Drive is very much intact, if you are a novice PC user, go and check your
Winodws:
Device manager >> disk Management
If it shows up there then the chances are 100% that yours is virus infected drive.
Take the help of DR Pro and they should recover your data for a decent price.
Please dont try any free/DIY tools as the situation may get worst and your data.
Cheers,
