 Post subject: Help recovering data from corrupteUSB Maxtor OneTouch Mini 4
PostPosted: February 25th, 2009, 11:31
When plugging in the USB Maxtor OneTouch 4 Mini into a Windows XP box the autoplay window comes up and it scans all of the files. Once that completes the drive shows up as the e:\ however when you try to access the drive it says the drive is not formatted would you like to format to continue. The drive has data on it which I need to recover. I also tried going to the command line and selecting the e:\ from the command prompt and when you try to change to that drive letter you get the error "Data error (cyclic redundancy check)." I downloaded the SeaTools and ran a short and long drive self test both of which passed, however all of the other tests said they were unavailable. Is there anything else I can try or any other software I can use to recover the data on this drive?
Thanks,
Andrew
 Post subject: Re: Help recovering data from corrupteUSB Maxtor OneTouch Mini 4
PostPosted: February 25th, 2009, 12:08
Find a local shop that does data recovery. This type of error will be inexpensive to fix.
www.datarecoveryne.com
PostPosted: February 25th, 2009, 14:30
Could be a Windows problem, try it on another computer first (and another OS, Mac or Linux) if you have access, if you get everything off, reformat it, test it completely.
PostPosted: February 25th, 2009, 14:49
I'm going to try mounting it with knoppix and see if that works. Thanks for the suggestion.
PostPosted: February 25th, 2009, 18:23
A reboot initiated chkdsk and looks like it solved the problem. Thanks for the help / suggestions.
PostPosted: February 26th, 2009, 11:24
Chkdsk can cause problems. Don't trust it. Since it ran itself, you can't put the sh!t back in the donkey, but it's generally best not to do it voluntarily.
PostPosted: February 26th, 2009, 11:25
Yeah, when I saw it come up I held my breath, but luckily it didn't erase everything. Thanks again.
Users browsing this forum: No registered users and 63 guests
