 Post subject: HDD Spins but not found in BIOS
PostPosted: March 4th, 2009, 17:09
Ok guys so I was running a badly needed defrag on an old laptop hdd and a few minutes after it completed (I let it just sit there afterwards) the screen went black and the machine was frozen. I powered down and when I turned the laptop back on I received the cannot find disk 0 error. I checked in the BIOS but the drive is not recognized there either. So I took the drive out and hooked it up to a desktop I have with an adapter. I can hear and feel it spinning, no clicking or weird noises, but the BIOS in this PC does not see the drive either. I am trying to locate another drive so I can switch out the logic board but I was wondering if there was anything else I could try first. Thanks!
 Post subject: Re: HDD Spins but not found in BIOS
PostPosted: March 4th, 2009, 17:32
Even if you didn't specify, sounds like a travelstar hdd... Changing the pcb is not a good idea.
PostPosted: March 4th, 2009, 17:46
Why does everyone assume its the pcb?
PostPosted: March 4th, 2009, 18:29
Oh if it was so simple :lol:
What I would give if all the problems could be fixed just by
swapping pcb's.
PostPosted: March 4th, 2009, 18:42
Yah at least try the freezer or double boiling first before assuming the pcb... :yayaya:
PostPosted: March 4th, 2009, 18:48
ROTFLMAO
PostPosted: March 4th, 2009, 22:53
You forgot the toaster oven.
PostPosted: March 5th, 2009, 11:59
Unless the drive is an older model IBM or Hitachi (pre-IBM) then changing the PCB will be of no value because there are flash ROM contents that have to be transferred as well. Frankly when faced with a spinning drive the PCB is not the most likely culprit.
Users browsing this forum: fouad19764, Google [Bot] and 53 guests
