 Post subject: WD800JD-75HKA1 F/W
PostPosted: April 8th, 2009, 9:06
F/W need it for the above drive
DCM:DSBHCTJCH
PCB:2060-001252-000 REV A
ACE or SD
XRONIS
T3 Professional Data Recovery
http://www.t3-recovery.com
 Post subject: Re: WD800JD-75HKA1 F/W
PostPosted: April 8th, 2009, 10:38
Here you go, in Salvation format.
All match apart from 1st letter of DCM.
Hope it helps
wdc wd800jd-75hka1.rar [1.49 MiB]
Downloaded 432 times
PostPosted: April 8th, 2009, 13:57
Thanks a lot friend...
i Hope me too
Xronis
PostPosted: April 8th, 2009, 13:59
any once know the XXHKXX is Caviar cyl 32 Viper family ?
Xronis
PostPosted: April 9th, 2009, 4:16
WD800JD-00HKA0 PCB: 2060-001252-000 REV A -> Mammoth (SATA)
U can use firmware (& PCB) from Mammoth (PATA) - of course with the same modules version
Mikippp
Users browsing this forum: Majestic-12 [Bot] and 56 guests
