 Post subject: ATMR 60GB - Corrupeted NVRAM
PostPosted: April 14th, 2009, 14:35
Hi to all hddgurus,
I am doing some research in the ATMR disk with the BSY problem.
So i pick a good disk working and edit the NVRAM and corrupted it, them write there something and save it.
The disk now it stays BSY forever i can not enter in the UDMA utility normal mode or safe mode always BSY.
I know the problem is the NVRAM but how can i pass the BSY problem and write there the NV-RAM that i have made backup before.
ZeBong
ZeBong
" Россия еще раз"
 Post subject: Re: ATMR 60GB - Corrupeted NVRAM
PostPosted: April 14th, 2009, 16:08
Use new ROM chip
www.datarecoveryne.com
PostPosted: April 14th, 2009, 17:05
Spildit wrote:
Reflash chip with external programmer ?
Yes i have that option i am just waiting for my eprom machine arrive :)
But in this case i am also interesting in reading the ROM to mach the nvram.
ZeBong
" Россия еще раз"
PostPosted: April 14th, 2009, 17:09
zebong wrote:
Hi to all hddgurus,
ZeBong
Simple:
With another working pcb + UDMA.
You can use the PCB as programmer, if you read the manual, and use the shorting methode. ;)
Janos
PostPosted: April 14th, 2009, 17:45
N.C. wrote:
Simple:
Janos
Hi Janos,
I try the shorting methode for this family ATMR did not work, could not pass to the ROM and them programmer the nvram.
ZeBong
" Россия еще раз"
PostPosted: April 14th, 2009, 17:54
zebong wrote:
Hi Janos,
Anyway, you can try to hotswap the rom only. :D
Use one soic-clip, or a simple DIP holder and wire out the 8 pin to another one...
Additionally, if the rom chip matches, you can use another model pcb wich can stand up with shorts. ;)
Janos
Users browsing this forum: Google [Bot], unknown and 83 guests
