 Post subject: Problems with the Maxtor Drivelock, can i remove it?
PostPosted: April 13th, 2009, 8:56
A few years ago i bought a Maxtor Onetouch External Harddrive. The harddrive inside was a Seagate Barracuda 7200.10. The onetouch has a option called Maxtor Drivelock. I loved that function, until the main controller of the external enclosure died..... So now i have a Seagate drive with a full lock on it and i can't reach the data anymore. Is there a possibility that i can remove this lock by my self? Is this the same lock as a ATA drivelock with password?
 Post subject: Re: Problems with the Maxtor Drivelock, can i remove it?
PostPosted: April 13th, 2009, 9:43
Try connecting the drive to PC and use MHDD. If it was ATA LOCKED and you know the password, with it you should unlock the drive.
PostPosted: April 13th, 2009, 10:11
It says in yellow letters: "Warning, this drive is locked by ata password". Unfortunately, i typed the password in i thought it was with the option 'unlock' and then '0', but it says fail. I have tried several passwords i know. :| It has the maximum security.
PostPosted: April 13th, 2009, 11:41
You will need special tools to unlock this one.
PostPosted: April 13th, 2009, 16:14
Is here a datarecovery pro available in Europe who can remove the ATA-password for me?
PostPosted: April 13th, 2009, 16:24
Yes, plenty. One it's me, you have a lot to choose from.
yes, there are several guys here in from europe.
Pcimage: UK,
Dobrevjetser: Belgium,
BlackST: Italy
myself: Hungary
and many more, I just ran a quick select in my mind... :)
PostPosted: April 13th, 2009, 21:06
i365 has a lab in Amsterdam
PostPosted: April 14th, 2009, 3:51
Have you tried AFF Repair Station to see if your drive is supported?
http://www.hdd-tools.com/products/rrs/
PostPosted: April 14th, 2009, 15:54
I tried AFF but the software says it cannot remove passwords from Seagate drives with maximum ATA security. I will send the drive to pcimage, thanks.
PostPosted: April 17th, 2009, 3:41
hehe some lab ;o)
PostPosted: April 29th, 2009, 4:18
Thanks to pcimage my drive is unlocked now. Quick service and not to expensive. Thanks Sean!
PostPosted: April 29th, 2009, 9:27
You are welcome :-)
Users browsing this forum: No registered users and 163 guests
