 Post subject: Fujitsu MHV2080BH - donor for PCB checking, will it work?
PostPosted: April 14th, 2009, 8:50
Need some help with donor disk checking.
I have:
Fujitsu MHV2080BH
PART No.: CA06672-B43300F1
Date: 2006-11
0BDD7C-00000029
Firmware: 00000029
with damaged PCB (spindle driver is hot, drive does not start)
For donor I have possibility of buying disk:
Fujitsu MHV2080BH
Date: 2006-11
0BDD7B-00000029 (here is ...7B, not 7C)
Firmware: 00000029
Will it work after PCB changing?
 Post subject: Re: Fujitsu MHV2080BH - donor for PCB checking, will it work?
PostPosted: April 14th, 2009, 9:31
Possibly, but not so likely.
Well worth a try though.
PostPosted: April 14th, 2009, 9:37
Sorry, the date of donor is 2006-06.
I haven't any other way, so I decided to buy this donor and change PCB.
PostPosted: April 14th, 2009, 9:39
Post the results please, would be interesting.
I have had mixed success in replacing MHV PCB's, sometimes they work even with different f/w. But mostly not and require ROM transfer.
PostPosted: April 14th, 2009, 10:29
I'm also interested what will be effect :) Now some days needed to ordering a donor disk.
PostPosted: April 20th, 2009, 7:33
I have changed new PDB today.
Disk is spinning, but not seen in bios...
PostPosted: April 20th, 2009, 7:58
...need to transfer ROM to new PCB...
Data Recovery Ireland
PostPosted: April 20th, 2009, 15:42
I am very curious as to how this one works out..Isn't the ROM embedded in MCU. MCU heatsunk to PCB..
PostPosted: April 21st, 2009, 9:31
I don't understand. Do You suggest that ROM is embedded in MCU?
PostPosted: May 6th, 2009, 3:13
Disk was working with new PCB. Problem was funny - my SATA cable was damaged because any other good disk didn't work with this cable :D Theese PCB's are compatible.
PostPosted: May 6th, 2009, 3:36
Nice to know, cheers.
Users browsing this forum: No registered users and 174 guests
