 Post subject: CD Protect with password in a MAC Computer
PostPosted: April 22nd, 2009, 16:58
Hi to all hddgurus,
Anyone have worked in a CD protected with password ?
The client have a MAC and when put the CD ask for a password .... and he dont know the password .
I connect the CD to a PC and can not read anything it appers blank 0MB.
Any comments,
ZeBong
ZeBong
" Россия еще раз"
 Post subject: Re: CD Protect with password in a MAC Computer
PostPosted: April 22nd, 2009, 18:03
PC will not know the MAC file strocture if the CD was formated to be used by MAC.
You will have to install something like MacDrive on the PC so that the PC can understand MAC format.
Thanks,
I have test with Macdisk , and nothing, now test with MacDrive, also nothing can not read the CD/DVD.
ZeBong
" Россия еще раз"
PostPosted: April 22nd, 2009, 18:23
I try also win-hex and nothing can not see any sector.
Will try the isobuster ..
ZeBong
" Россия еще раз"
PostPosted: April 22nd, 2009, 18:32
Spildit wrote:
Ok, after that tell me how it went !
Hi nothing new happen.....
Will try this in a MAC computer to see how can i remove the password, by the way any good program for MAC to edit sectors ?
ZeBong
ZeBong
" Россия еще раз"
PostPosted: April 23rd, 2009, 13:33
Thanks for the Help,
But the problem is this:
I think the cd is BAD
ZeBong
" Россия еще раз"
PostPosted: April 23rd, 2009, 14:39
If it asks for a password, then it is likely to be password protected :shock: . Have you tried creating an image of the drive with Winhex or X-Ways? Can you post a screenshot of the password dialog box that you see?
Data Recovery Ireland
PostPosted: April 23rd, 2009, 15:01
I would also be interested in the sector view.... is it all zeros?
PostPosted: April 23rd, 2009, 15:21
I can not edit, any sector, it take a lot off time, and it appear as BAD SECTOR
Will try to read it in a MAC to see the result, maybe the CD is not reading!
Will post them the result.
Thanks to all
ZeBong
" Россия еще раз"
PostPosted: April 23rd, 2009, 15:24
That does sound like read errors.... I would suggest using ImgBurn on the PC to make an image of the disc. It will tell you if its having read errors or whatever the problem is.
PostPosted: April 24th, 2009, 0:50
Can you look at the back of the CD and see if anything is written??? If something is written, try different drive. Sometimes, one drive can read a slightly damaged CD/DVDs while the other drives can't due to the surface damages.
So far, I'm getting a really good luck with the Sony external DVD writers to read damaged disks. I also use read-only DVD drives for the disck that can't be read on my Sony.
PostPosted: April 24th, 2009, 16:50
thanks to all,
I am waiting for the MAC computer to read it there and see what happen them post here the result.
ZeBong
ZeBong
" Россия еще раз"
PostPosted: April 26th, 2009, 5:44
Might be a silly suggestion, but is there any chance disk is a RW disk that has been formatted? Even password protected CD should have a valid LBA and at least accessible HEX.
Does customer know the software used to protect CD? I am not aware of standard CD protection feature on Apple OS.
PostPosted: May 6th, 2009, 14:52
Hi Again,
I try to read the dvd on the MAC, but the problem is not password protect .....
No the client say´s that can not read the CD :evil:
i try in the PC with other ODD and now i could get 1 track with ISOBUSTER, but nothing there.
i try to edit the sector with winhex and it give error in sector 0.
ZeBong
" Россия еще раз"
PostPosted: May 6th, 2009, 16:37
It's a closed DVD, noyt a hard drive !!! Why did you think that you could "edit" something on a DVD that is already written ?
when i say "edit" off course i can not edit/write a CD/DVD, but i can see the sectors.
ZeBong
" Россия еще раз"
PostPosted: May 6th, 2009, 20:42
Did you try to image it with imgburn or something else?
Users browsing this forum: No registered users and 184 guests
