 Post subject: Samsung HD321KJ
PostPosted: May 8th, 2009, 12:17
Hi, another quick question for everyone. I have been working with a Samsung HD321KJ that I did a head swap with. For the donor I just matched model and firmware. The swap worked fine but about halfway through the new heads failed. Now the only replacement drives I can find don't have the same firmware. Do you think that will matter seeing that I only need the heads?
Thanks for your help.
 Post subject: Re: Samsung HD321KJ
PostPosted: May 8th, 2009, 12:30
What do you know about Samsungs?
PostPosted: May 8th, 2009, 12:37
Not that much, it seems like it's always heads that work with them. I have not had to do any work with firmware, especially these newer drives.
PostPosted: May 8th, 2009, 13:03
...because are undocumented. You need to match many things, and if there is a scored platter it will kill any new headset. Beside physical conditions, if you analyze the MC you have all the needed info about what to match !
PostPosted: May 8th, 2009, 14:42
Thanks for the reply. I do believe there is some damage to the surface. I managed to image about 80% of the drive so far. I was hoping with one more set of heads, trying to avoid where I think the damage is, that I could get most of what is left. So far with these drives, matching firmware and Rev. have worked every time. If I do take a chance with the mismatched drive and the heads work I will post the results. Thanks.
PostPosted: May 8th, 2009, 15:26
You were simply lucky : if you don't match "some things", won't work or will work partially. In any case, 1st thing to do is proper diagnose : I mean check platter surface condition. I know, it's multiplatter and can be difficult....
PostPosted: May 9th, 2009, 3:22
Check your image. Maybe 80% is enough.
PostPosted: May 9th, 2009, 4:02
Previous Samsung drives were easy to identify drive parts. Now it's "less easy".
PostPosted: May 9th, 2009, 10:00
I may be OK. Going through what I did manage to image, most of the photo's are ok. Just need to check some QuickBooks files and I should be good to go. Thanks guys..
PostPosted: May 9th, 2009, 10:02
Seems like it's getting that way for most drives. I think that is the most difficult part of our jobs, identifying and locating components..
PostPosted: May 9th, 2009, 10:57
for me the problem lies elsewhere : until all the people will simply rely on "click and go" solutions and few will do R & D (the engine of everything!) , the problems will continue :mrgreen:
Users browsing this forum: No registered users and 124 guests
