 Post subject: WD800JD-75HKA1 always BSY
PostPosted: May 3rd, 2009, 13:30
Checked Platters & Heads. Changed Identical PCB and the ROM also. BUT always BSY...
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
 Post subject: Re: WD800JD-75HKA1 always BSY
PostPosted: May 3rd, 2009, 14:13
always BSY ....?
clicking ....?
Xronis
T3 Professional Data Recovery
http://www.t3-recovery.com
PostPosted: May 3rd, 2009, 14:27
I have BSY status on indicator but no power at all. No clicking...
__________
THANK YOU
SHAHI
PostPosted: May 3rd, 2009, 14:28
And the ROM is also fine.
__________
THANK YOU
SHAHI
PostPosted: May 13th, 2009, 14:54
check preamp .
PostPosted: May 13th, 2009, 19:05
How is identified when u use the native PCB and the Donno PCB?
PostPosted: May 15th, 2009, 18:00
It's spinning or not?
PostPosted: May 15th, 2009, 19:08
I had some cases like that always BSY, and i it not SPIN, but if you change the PCB it will be spin.
Try to find a donor PCB.
ZeBong
" Россия еще раз"
Users browsing this forum: No registered users and 174 guests
