 Post subject: western digital mybook not working ?????
PostPosted: May 8th, 2009, 19:53
any advice in this before i go into it more and spend some $$$$
Western Digital My Book
hard drive can be heared starting up so that rules out motor problem
then you can hear small clicking sound and then it stops
connected the drive up to pc3000 does not see the drive at all and no Communication with the board itself with the controller test.
tried hdd tool online can not see the drive at all.
im thinking this might be a fault in the logic board itself damaged.
dont think its the headstack as there no commmunication with the logic board at all.
common problem with these Western Digital My Book are overheating.
any one come across this before can i just match up the following and get this working again
western digital wd caviar se
mdl 2500jb-00rea0
dcm h8bhntjca
wd p/n WD2500JB-OOREAO
cheers
 Post subject: Re: western digital mybook not working ?????
PostPosted: May 8th, 2009, 21:13
What happened when you tried a new PCB?
PostPosted: May 9th, 2009, 1:42
99% is a head problem, instead. The drive was shocked (probably). Simple pcb swap won't work. There is a small % probability about pcb, a diagnose with WD tool will leave no doubt.
PostPosted: May 9th, 2009, 4:39
yep looks like the power supply itself is to blame.
so next step would be to do a logic board swap.
and hope it did not take out the heads too.
i would had thought if the headstack was damaged
your still get some Communication from the pcb board itself
tried pc3000 and that can not see the drive at all
PostPosted: May 9th, 2009, 4:40
PostPosted: May 9th, 2009, 4:52
Do a correct diagnose FIRST, no "attempts" .
PostPosted: May 10th, 2009, 4:18
ok i check out the logic board for any damaged fuses that are gone.
but for sure the only way next is by getting a replacement logic board
and if that does not work
headstack is damaged.
its for sure not firmware corruption.
any other options on what to check.
PostPosted: May 10th, 2009, 5:22
99% heads
PostPosted: May 11th, 2009, 9:07
Did u tried to edit head map on PSV mode, and tried to tried did test from heads , some times there are not all heads off , and u could tried some methods before did head swap
PostPosted: May 11th, 2009, 17:05
I'm confused. He's saying that he gets no communication with the drive at all (i.e. no ATA registers light up or anything) and everyone's telling him its the heads?
PostPosted: May 11th, 2009, 17:29
He says it spins up, ticks, then spins down again. Didn't see a mention of ATA registers.
I'm only going by what I can glean from the info given, but from experience this is classic bad heads symptoms. Could be wrong of course.
PostPosted: May 14th, 2009, 0:31
checked the drive out again does not pickup at all.
no bad connection or blown parts.
loaded up pc3000 no communication with the drive at all.
so if there no communication with the logic board at all
does this mean its faulty or the headstack itself
so next option is that the headstack is faulty.
im 85% sure its the faulty heads
but the next options is swapping them over.
that is going to be the last resort.
is the exchanging of the headstack easy or are these drives using some type of special alignment before they are sealed up.
PostPosted: May 14th, 2009, 0:43
So to clarify, what do the ATA registers look like?
PostPosted: May 21st, 2009, 5:24
there is no comms with the board itself.
so no ata commands
PostPosted: May 21st, 2009, 5:40
remove the board from the drive and try it,
if no communication at all, then replace the board.
PostPosted: May 21st, 2009, 14:37
I bet it's a ( PCB ) Problem until there's no ata registers show
PostPosted: May 22nd, 2009, 9:17
ppl that sell those... Say that those equipments have lot of RMA's ...
They say it is because of the power supply having no power switches... it sends peaks when it is plugged to the electrical wall socket
PostPosted: May 26th, 2009, 3:07
yep your correct on the power supply problem where it sends peaks when its plugged to the electrical wall socket.
no protection at all.
this is why its gone in the first place
the qeastion is has it taken the headstack with the logic board
so now im trying to track down a new logic board
but not having much luck at all as none of our sources have this model WD2500JB OOREAO
any ideas what we could try can we swap the rom over ??????
cheerss guys :beer: :beer: :beer: :beer: :beer:
PostPosted: May 26th, 2009, 12:48
According to my list some sabre drives should have the same PCB (701292)... look for JH or JJ.
PostPosted: May 26th, 2009, 15:01
have you checked ebay? From what you were saying, it appears that one of the heads might have failed. Consequently to that, the board went out while you were testing it. This happens often with WD drives; the board dies for no reason. For the board search, you may not need the exact size; if you have something in the same family, you can solder the rom on it. If the board is really dead, you may not read it with pc3000.
The last word from the dying patient, data.
www.datamediarecovery.com
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 144 guests
