 Post subject: Replacement diode for WD2500JB
PostPosted: May 28th, 2009, 1:37
Hi people.
I have a WD drive 2500JB that has a blown diode (labelled D6), right next to the power plug. No other chips seemed cracked or scortched.
I'm trying to get data from this drive.
Can I just bypass this diode?
Or should i replace it with another diode... and if so what rating?
From what I can make out of the blistered top of the diode, it is a
STMicroelectronics diode, all I could read was the ST symbol, and the code GP643 (I think). I searched ST.com without luck.
From the customer's report, it sounds like their house copped a power spike.
Thanks in anticipation.
JoshAU
 Post subject: Re: Replacement diode for WD2500JB
PostPosted: May 28th, 2009, 15:16
Just remove the diode .
PostPosted: May 29th, 2009, 3:21
Well I'll be.....
Thats even easier than I thought!
I had assumed that the diode went between the circuit and the 12volt rail... so by removing the diode it would just break the circuit.
I guess they run the diode between 12V and ground instead, so if a reverse current goes through it it shorts to ground, killing the diode.
But hey I'm not an electrician.
And yes, removing the diode works.
Thanks for the succinct answer, rameez.
I will probably try replacing the diode once I have got the data off it, as it appears perfectly fine, except for the scorch mark. :D
I'll probably take a diode from one of the dozen or so faulty WD800 drives that I have lying around, unless someone here can advise on a suitable replacement diode.
Thanks once again, and have a good weekend.
JoshAU
PostPosted: May 29th, 2009, 10:47
If you want to read more about this search the forum for TVS.
PostPosted: May 31st, 2009, 19:47
Thanks for the extra info, drccsc.
I appreciate it.
Nice to know what its purpose was.
JoshAU
Users browsing this forum: Majestic-12 [Bot] and 133 guests
