WD5000AAJS
June 9th, 2009, 23:13
Questions to Gurus!!!
If there are physical defects in the SA area or physical bad sectors in the SA of WD5000 series or ROYL, how does the drive act?
Also, what is the chance of hotswap in this senario????
PMs are welcome!!!!!
Thanks in Advance!!
Re: WD5000AAJS
June 10th, 2009, 9:55
If SA has physical damaged u could tried with Copy 1 but some times a lot of bad sectors at SA damaged could be related to a bad head check that
