 Post subject: western digital head swap question
PostPosted: June 18th, 2009, 16:31
hi,
i have a wd3200aavs00ztb dcm:hhrnht2mab the heads are damaged. i would like to know what would be the closest substitute to use for this drive, since finding an exact donor is proving difficult.
thanks in advance.
 Post subject: Re: western digital head swap question
PostPosted: June 18th, 2009, 17:08
... and the most difficult is the alignment, after found the donor... 8)
PostPosted: June 18th, 2009, 19:12
qwameske wrote:
hi,
thanks in advance.
You should at least be able to match the full model number WD3200AAVS - ?????? with a little bit of searching and patience. You need even more luck with the alignment.
Zero Alpha: zeroalpha.com.au
Users browsing this forum: No registered users and 170 guests
