 Post subject: WD1200BEVS-60LAT0, DCM: HCTJABN
PostPosted: June 25th, 2009, 18:30
I am looking for a WD laptop hard drive, for heads change:
WD1200BEVS-60LAT0
DCM: HCTJABN
I have been told DCM is very important. Please let me know, what's the closest match I need to get, to make it work again.
Thank you in advance.
 Post subject: Re: WD1200BEVS-60LAT0, DCM: HCTJABN
PostPosted: June 26th, 2009, 3:34
Have you done a head exchange on one of these before?
PostPosted: June 28th, 2009, 14:28
Yes, but drive is clicking. I think, heads are not compatible.
Also I know, with WD there a slim chance to recover it.
Any suggestions?
PostPosted: June 28th, 2009, 16:23
You've already changed the heads?
What was the full model and DCM of the donor you used?
PostPosted: June 28th, 2009, 17:28
Yes. I used heads from:
WD1200BEVS-00LAT0, with DCM: H0TJBNB
PostPosted: June 29th, 2009, 0:56
Insufficient compatibility.
PostPosted: June 29th, 2009, 3:35
Agree.
btw, were any of the heads detached from the arms when u removed the HDA?
PostPosted: June 29th, 2009, 14:36
Well, I said heads I used are not compatible.
The two out of four heads were visibly damaged. It could be even bad media (but there is no scratch).
Please let me know, what would be the closest match to this model for heads change:
WD1200BEVS-60LAT0
DCM: HCTJABN
Thank you.
PostPosted: June 29th, 2009, 18:24
It's me again.
original is:
WD1200BEVS-60LAT0
DCM: HCTJABN
I have just found this one:
WD1200BEVS-60LAT0
DCM: H0AJANB
Thank you.
Users browsing this forum: Majestic-12 [Bot] and 133 guests
