 Post subject: WD5000AAJS-22TKA0
PostPosted: June 25th, 2009, 4:02
Hi all,
i have a DR case for WD5000AAJS drive,
patient drive's pcb is dead, no power nothing
i have a excact match donor, swapped the pcb but not compatiable
i tried to read patient in kernel mode on pc3k but no access
i resoldered the marvel chip on patient and put it on donor pcb
unfortuantley nothing is changed , pcb is still dead
so, the main chipn on the patient drive's pcb is not working ,
in this case how can i get the data from this hdd
any suggestion please?
 Post subject: Re: WD5000AAJS-22TKA0
PostPosted: June 25th, 2009, 4:43
Is this a ROYL drive?
PostPosted: June 25th, 2009, 4:55
i think ,,yes it is royl family
PostPosted: June 25th, 2009, 6:05
You should be able to rebuild ROM on non native pcb with Acelab (genuine) pc3000 or Salvation Data WD Doctor.
PostPosted: June 29th, 2009, 17:44
ibcho wrote:
Hi all,
You have likely damaged donor pcb also. Spaz is right, you can run ROM recovery from PC3000, from your post it looks like you have it. Is it genuine UDMA?
PostPosted: June 29th, 2009, 23:15
PC3K requires a loader to work with WD SA from safe mode (which is kinda stupid IMHO), anyway in order to read original SA and assemble original ROM you need to use module 11 (as a loader) and PCB from a donor drive which supposed to be any size TNA, TKA, TMA or TRA (Tornado3) model, PATA or SATA
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 145 guests
