 Post subject: PLEASE HELPPPP!Damage One of partitions
PostPosted: July 10th, 2009, 7:09
Hello to All,
I have 4 hard disk drive,
when I disconnect my hard drives and reconnect them,SATA numbers disarranged.
For example My SATA1 that have been Maxtor 1Tb,Changed to Seagate 500Gb.
in windows startup,Scandisk scanned my partitions and thinks drive M: is previous partition in Seagate 500Gb.
Now my M:NTFS 930 Gb partition is 24.2Gb(size same one of my partitions that located in other harddisk Seagate 500Gb)!! and this is Fat32.
I can recover my M: list files and folders,But then I recover them,there is no correct file and failed to open many of them.
In recovering Utilities,file allocation table 2 for M:NTFS is available and allocation table 1 have been lost.
So scandisk did not find any problems in my partition.
In windows manager Size of Partition is 930Gb,and in My computer Size is 24.2Gb.
In new Partition there is 2 Folders Found.000 and Found.001.
Now how I can fix this problem and recover from NTFS Allocation Table 2?
I test Many of Recovering Software,But there is no chance to recover data.
PLEASE HELPP MEEEEEEEEE
Moderator edit: this is a spam post from EASEUS
 Post subject: Re: PLEASE HELPPPP!Damage One of partitions
PostPosted: July 10th, 2009, 22:34
Hm. It sounds like you unplugged your disk drives while the computer was running. Is that right?
PostPosted: July 11th, 2009, 17:40
Never run a recovery program on your origianal disk. Make a copy of this disk first before attenpting to repair or recover it.
Next get a good partition recovrey program or DR recovery program like R Studio
Run it in the cloned disk to find your data
Never disconnect HDD on a running system
Do not use free software to try and fix this problem it won't work
Invest in good software package and read the forum there is lots of suggestions out there on what to use. One good post comes to mind and lists a lot of software commercial that was tested and results of the test. Find and read this for startes before going on with all this.
Last result consult a pro in your area it is a logical recovery and should not cost you too much to have this one done for you
Iorana Haraharaini
PostPosted: July 13th, 2009, 6:22
Thanx Guys,
Problem Solved.
I could recover my lost Data with "EASEUS Data Recovery Wizard Professional 4.3.6".
It is very Powerful Software for Recovering Data and recovered 100% of My Data.
PostPosted: July 13th, 2009, 22:51
hamed_a wrote:
Thanx Guys,
Problem Solved.
This sure looks like another blatant ad for Easeus
PostPosted: July 13th, 2009, 23:04
No end user is going to write that last line....hamed next time make the ad look less obvious....take pride in your advertising skills man...we demand more quality these days...thats just plain slop... :yayaya:
Users browsing this forum: Majestic-12 [Bot] and 138 guests
