Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
 Post subject: Re: ST380011A not recognize in bios
PostPosted: January 27th, 2009, 11:42
T>/2
2>s0EDD7,0
2>r,6,1
2>B200,200
That should show you the buffer with the password. Then you can edit the buffer and write it down, or get the pass and in Victoria, MHDD or some other program unlock the drive.
DataRecovery.bg
PostPosted: January 27th, 2009, 13:49
OK, it look like this
2>s0EDD7,0
2>r,6,1
2>B200,200
buffer 0200 comparing to 0200 RD:0200:10:00 WR:0210:10:00
Addr 0 1 2 3 4 5 6 7 8 9 A B C D E F 10 1 2 3 4 5 6 7 8 9 A B C D E F
040000 01005365 61676174 65202020 20202020 20202020 20202020 20202020 20202020
040020 20200182 500241A8 10624188 04000480 4018400E 00020132 00865000 00004188
040040 01220220 28100000 00000000 00000000 00000000 00000000 00000000 00000000
040060 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
040080 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
0400A0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
0400C0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
0400E0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
040100 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
040120 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
040140 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
040160 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
040180 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
0401A0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
0401C0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
0401E0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
040200 6FFEDFBF F7BBFDFE DFFFFFFF F7FFF5FF FFFAFFFF FFFBF7FB BFFEFFFD FFFFDFFF
2>
and where is password?
PostPosted: January 27th, 2009, 14:27
ok found it,,,
Segate and 25 "spaces" ...
Thank you so much.. Samo
is this is experiance? this terminal codes,i understand, but where to find? This is hard work..and experiance..
Thank you all, once again.
PostPosted: August 4th, 2009, 23:56
Samo wrote:
T>/2
2>s0EDD7,0
2>r,6,1
2>B200,200
This is a little bit of an old post but... any tips on how to edit the buffer and "write it down" I havnt figured out how to do this without purchasing software...
Users browsing this forum: No registered users and 121 guests
