 Post subject: i have bought deskstar P7K500 HDP725025GLA380 0A35399 3.5" 2
PostPosted: August 14th, 2009, 8:13
I HAVE 2 QUESTIONS
1 . I HAD BOUGHT NEW HITACHI SATA HDD....I CONNECTED REVERSED POWER SUPPLY ACCIDENTLY....SO PCB BURNED & FRIED....ITS TVS diode HAS BURNED CRACKED....SO NOW should i remove it & start HDD or replace that diode with another & then start so that it will be under protection....
2.. after that accident im worried that whether my NVRAM IS OK or not
 Post subject: Re: i have bought deskstar P7K500 HDP725025GLA380 0A35399 3.5" 2
PostPosted: August 14th, 2009, 8:23
I guess you can either try and RMA it or simply replace the TVS.
Zero Alpha: zeroalpha.com.au
PostPosted: August 17th, 2009, 1:54
i bought new HDD.....removed NVRAM from old PCB & soldered it into new PCB of same model....i got my whole 250 GB of data back......im very happy ......thank you...
Users browsing this forum: No registered users and 170 guests
