 Post subject: Unlocking failed HTS541080S9SA00
PostPosted: September 7th, 2009, 23:14
Hi guys
Does anyone manage to unlock password on HTS541080G9SA00 using UDMA? I could not get it to work. Only SD could.
 Post subject: Re: Unlocking failed HTS541080S9SA00
PostPosted: September 8th, 2009, 9:20
Can you access NVRAM to change the Boot Flag? Or maybe try to access SA with different PCB and NVRAM to replace security module?
Have not had ATA locked G9SA so cant really offer much more help im afraid.
PostPosted: September 8th, 2009, 21:39
Yes i could access NVRAM, what should i change the bootflag to? Currently 0x01.
PostPosted: September 9th, 2009, 2:31
Make a backup of the NVRAM, then change it to 0x00. this should start the drive from Factory copy which should not be protected. If this does not work I will put ATA password on good drive here and try remove it and let you know.
PostPosted: September 9th, 2009, 2:51
thanks hddguy, bootflag 00 will not get access to ICES mod, only 4 or 5 RSV mods
PostPosted: September 9th, 2009, 9:49
I don't think this is correct
You should have access to all SA
PostPosted: September 9th, 2009, 22:11
Thanks guys I got it working. I made a few mistakes along the way.
PostPosted: September 12th, 2009, 11:09
What mistakes did you do ?
Users browsing this forum: Bing [Bot], Google [Bot] and 204 guests
