 Post subject: Samsung MP0402H Motor problem
PostPosted: July 8th, 2009, 11:35
I have MP0402H which motor doesn't stabilize rotation, LED gives me error code 0x16.
Can I move platter, pcb and heads to the MP0603H drive? Both drives are M40 Rev.A.
Motor label of MP0402H is M40 NSX8202109 and MP0603H is M40 BSXC272108
Data is not worth very much :)
Thanks in advance
 Post subject: Re: Samsung MP0402H Motor problem
PostPosted: July 8th, 2009, 11:37
Read this before do anything:
results-the-yourself-solutions-t11912.html
Ps: i bet your drive have no motor problem, this is something else.
Janos
PostPosted: July 8th, 2009, 11:44
"0x16" can be caused by many things. Check THOROUGHLY everything.
PCB swap alone WON'T work. About using different heads, you have to check head mapping to use heads from other drives, albeit from same family (M40).
PostPosted: July 8th, 2009, 11:49
Janos
I am aware of DIY results.
I have done platter change successfully a few times and want to learn more.
PostPosted: July 8th, 2009, 11:52
:rip: :roll:
This is all what i can say for this.
I have seen some drive with similar problem, but none was motor problem.
The spindler works or stucked, no other option in this model.
Janos
PostPosted: July 8th, 2009, 11:58
Learn by damage ? :mrgreen:
PostPosted: July 8th, 2009, 13:14
Buy a new drive and move on, otherwise you only will get frastrated with this issue.
www.datarecoveryne.com
PostPosted: July 8th, 2009, 14:13
Never seen bad motor in this series.
I think your problem is somewhere else.
PostPosted: September 11th, 2009, 14:45
Data recovered 100%. And yes, it wasn't motor problem.
Thank you all for hints.
PostPosted: September 12th, 2009, 7:56
what was the problem? It's not helpful starting a thread and not following it up.
PostPosted: September 12th, 2009, 9:25
pcb I bet.
PostPosted: September 15th, 2009, 14:37
yes, it was pcb. I changed rom to another pcb and recovered data.
Users browsing this forum: Bing [Bot], Google [Bot] and 190 guests
cron
