 Post subject: Back with another Case: WD 1600AAJS
PostPosted: September 18th, 2009, 0:07
Hi happy people. I'm back because you are my new favorite people regarding Hdd and stuff like that. Recently i repair a hdd with your help and now i want to help another person but, well... can´t resolve.
This is the case: The HDD just stopped to work. Suddenly and without warning. No spin, no recognition, no nothing.
I was thinking "The TV´s Again???" well we live in a area with poor electrical conditions, and few people has the precaution of use a UPS for protection.
Well before i start to mess with the HDD Pcb i want your opinion if i´m correct with my diagnostic.
here are the reglamentary pictures.
The damaged PCB. Ans you can see, everything is nice and with no sign of burning or damaged device.
A Zoom image of the area with the "d1" and "d2" i suspect are the Tv´s i suppose i have to remove.
The Data from the Hdd Front.
What you think/opine/advice people. I proceed with the remove of the D1 and d2 or the Tvs can be other "component.
Thanks in advance for the info.
 Post subject: Re: Back with another Case: WD 1600AAJS
PostPosted: September 18th, 2009, 19:38
try to measure the PCB components. like the IC motor controller
or the MCU, then put the results
good luck
PostPosted: September 19th, 2009, 0:04
Like unknown told u, check SMD´s Diodes, resistors, capacitors, MOSFET, etc i should start measuring continusly, check too if there are no shortcut , a good tips should be put +12v +5v from u PS and check if the power supply start up, if no there is a shortcut , and u need to find it, if spins u need to measure each SMD component, and check it another tip on this model u cannot replace PCB, ROM its embedded on MCU,
Users browsing this forum: Google [Bot] and 191 guests
