Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
 Post subject: Re: Toshiba HDD2188 hard drive revival....
PostPosted: September 25th, 2009, 2:55
"MHDD could not find the hard drive" vs "Model #, serial, and firmware are all correct"
Which is it?
PostPosted: September 25th, 2009, 8:52
I couldn't get MHDD to do anything. It couldn't locate anything. I even hooked up a known good hard drive, and got the same message. It kept saying "disk not ready"( I have the damaged hard drive slaved with a USB adapter) I tried HDDscan, and got the results I posted.
PostPosted: September 25th, 2009, 9:00
USB adapters block most of the low level access.
To use MHDD you'll need to attach the harddisk (through an 2.5" - 3.5" adapter since its a notebook drive) directly to the motherboard.
Dobre
Murphy was an optimist
PostPosted: September 25th, 2009, 17:37
That would explain a lot then. HDDscan read it easily, but I don't know what the results of the surface test mean. what's the differnce between hddscan and mhdd? Looks to me that HDDscan has all of the same functions, and then some.
PostPosted: September 26th, 2009, 19:52
I ran a smart scan, using HDDscan, and here are the results. Could somone please look this over, and decipher for me? ( #199, Ultradma crc error count, was flagged)
HDDScan S.M.A.R.T. Report
Model: TOSHIBA MK8025GAS
Firmware: KA024A
Serial: 94LP6040T
LBA: 156301488
Report By: HDDScan for Windows version 3.1
Report Date: 9/26/2009 6:17:22 PM
Num Attribute Name Value Worst Raw(hex) Threshold
001 Raw Read Error Rate 100 100 00000000-0000 050
002 Throughput performance 100 100 00000000-0000 050
003 Spin Up Time 100 100 00000000-0652 001
004 Start/Stop Count 100 100 00000000-1370 000
005 Reallocation Sector Count 100 100 00000000-0000 050
007 Seek Error Rate 100 100 00000000-0000 050
008 Seek time Perfomance 100 100 00000000-0000 050
009 PowerOn Hours Count 068 068 00000000-32C7 000
010 Spin Retry Count 199 100 00000000-0000 030
012 Device Power Cycle Count 100 100 00000000-052C 000
192 Power-off retract count 100 100 00000000-0040 000
193 Load/unload cycle count 043 043 00000008-B4F1 000
194 HDA Temperature 100 100 29 C 000
196 Reallocation Event Count 100 100 00000000-0000 000
197 Current Pending Sector Count 100 100 00000000-0000 000
198 Uncorrectable Sector Count 100 100 00000000-0000 000
199 UltraDMA CRC Error Count 200 200 00000000-02FD 000
220 Disk shift 100 100 00000000-0063 000
222 Loaded hours 077 077 00000000-256B 000
223 Load retry count 100 100 00000000-0000 000
224 Load friction 100 100 00000000-0000 000
226 Load-in time 100 100 00000000-00D8 000
240 Head flying hours 100 100 00000000-0000 001
PostPosted: September 27th, 2009, 1:05
Looks normal to me.
PostPosted: September 27th, 2009, 10:42
The drive shows up as e/ drive when I slave it, and when i click on it, I get this error message
E:\ is not accessible. The wrong diskette is in the drive. Insert (Volume Serial Number: )
It shows up as a RAW file, 0 bytes. ( Back story, real quick....laptop gets wet, starts going into never ending rebooting cycle. Hard drive switches to RAW. I know the data is still on there, just trying to get it off) Is there a home program I can use that would work? I've tried most of the freeware stuff already, amd most of them didn't see the drive, and those that did, would not access it. Any suggestions?
PostPosted: September 27th, 2009, 13:57
Image to known good drive or image file, then try something like r-studio.
Users browsing this forum: No registered users and 193 guests
