 Post subject: Hard Drive not working, grinding sound.
PostPosted: October 6th, 2009, 19:26
Hi I have a Seagate FreeAgent 500gb hard drive that is no longer being detect and is making a grinding sound. The hard drive fell on the floor. Does the hard drive head need to be replace?
 Post subject: Re: Hard Drive not working, grinding sound.
PostPosted: October 6th, 2009, 19:37
Time for RMA... :mrgreen:
PostPosted: October 6th, 2009, 23:45
can the data be retrieved and what would cause the grinding sound?
PostPosted: October 7th, 2009, 2:41
The grinding sound is either the bearings or your data being turned into dust.
Zero Alpha: zeroalpha.com.au
PostPosted: October 7th, 2009, 2:43
If you need the data, then this one NEEDS to go to a pro. There is NOTHING you can do for this one I'm afraid to say.
PostPosted: October 7th, 2009, 10:51
i think its the bearings, cause when i pick up the drive (I removed the drive from the external FreeAgent case) it sounds like its wombling inside.
just a rough estimate if it was the bearings how much would it cost to fix?
PostPosted: October 7th, 2009, 13:56
Ah ha!
Broken spindle, 99% for sure.
Have done these before, any decent pro should be able to handle this.
Users browsing this forum: Majestic-12 [Bot] and 114 guests
