 Post subject: How do I change diagnostic level /x in C program
PostPosted: October 7th, 2009, 11:17
I am currently working on some kind of low level HDD diag and recovery tool project.
I have built RS232-TTL converter and connected HDD using it. Now Trying to build a GUI tool to communicate to HDD and do requested things.
Till Now I am successful in writing C code for sending single byte diagnostic commands to Seagate SATA drive. BUt when I am sending a multibyte command like "/1", it is giving me output like "Input Command Error".
I am using BYTE array to scan user input and passing char * pointer to that array to my function which writes that string to COM port i.e HDD.
Note : All diagnostic commands are working properly while connected with HyperTerminal or Putty.
Is anybody having any idea, suggestion for this.
-ADITYA
 Post subject: Re: How do I change diagnostic level /x in C program
PostPosted: October 7th, 2009, 16:02
Introduce a delay between characters sent and lines.
PostPosted: October 8th, 2009, 4:24
you do need a delay. You also (as I found with my machine) need the GND connected or you get bullsh1t echo
PostPosted: October 8th, 2009, 5:34
Hurray!
the problem is resolved as line feed is added to data to be written
(scanf( ) omits the \n so i added it explicitly) :D
PostPosted: October 9th, 2009, 4:11
thats the easy bit :P
Users browsing this forum: Majestic-12 [Bot] and 100 guests
