 Post subject: Maxtor DiamondMax 10 6B200 - Failed Q501
PostPosted: October 10th, 2009, 8:36
Hi guys,
Last night my Maxtor DiamondMax 10 6B200 (A 200GB SATA150 HDD manufactured January 2005) would not detect in BIOS or Windows XP. I checked everything, connections etc, realised that it was not even spinning up i.e. no power and concluded that something had gone on the PCB.
I know that the drive works because I have another of the exact same drive and I swapped the PCB and grabbed all the data from it. Upon careful visual inspection of the PCB and measuring with my multimeter, I can only see that Q501 is blown.
On this transistor is printed "J3076" which I believe makes it a 2SC3076 ?
However I can't find this component anywhere.. I have seen a couple of similar components that may work but I was just wondering whether anyone has an exact replacement, or knows where I could get one? (in the UK)
Cheers! :mrgreen:
CJ.
 Post subject: Re: Maxtor DiamondMax 10 6B200 - Failed Q501
PostPosted: October 10th, 2009, 18:35
pcimage, he is a pro and in UK
PostPosted: October 11th, 2009, 5:49
I have sent him a PM, I'm just looking for either an exact replacement Q501 transistor, or the part number of an acceptable replacement. I'm not looking for a data recovery service, as per the post above I've already recovered my data, I just want to repair my drive instead of throwing it away :wink:
PostPosted: October 11th, 2009, 18:01
This drive is allready too old to be trustable.
If you don't want bad for yourself, let this drive die, and get new one.
Janos
PostPosted: October 11th, 2009, 19:08
J3076 is probably a FJD3076 NPN transistor, 40V, 2A, lo-sat:
http://fairchildsemi.tv/ds/FJ/FJD3076.pdf
It is specified for audio frequencies.
PostPosted: October 12th, 2009, 0:08
The following URL confirms that the marking code for the FJD3076 is J3076:
http://www.fairchildsemi.com/TopMarkSea ... at=FJD3076
PostPosted: October 12th, 2009, 6:27
FJD3076 = 2SD1758 [Rohm]
Mikippp
Users browsing this forum: Google [Bot] and 104 guests
