 Post subject: Need to Format Target Drive for Cloning Purposes?
PostPosted: October 12th, 2009, 8:31
Lets say you have two drives
Drive A - You want to Copy
Drive B - Target Disk. Brand new disk. Unformatted.
Do you have to format the target drive (drive B) in order for the clone process to be successful?
 Post subject: Re: Need to Format Target Drive for Cloning Purposes?
PostPosted: October 12th, 2009, 8:50
Most new drives have FFs or 00s written on them.
But to be safe, and as a matter of standard procedure, ANY drive that is the clone target should be SECURE ERASED first!
http://www.datasaversllc.com
No, not neccessary. ALL data is overwritten anyway (except for bad sectors, but these can be overwritten too if cloning device/software if properly configured).
New disks are (supposed to be)clean.
Only when you use an old disk you should wipe it, reformatting is not neccessary.
Dobre
Murphy was an optimist
PostPosted: October 12th, 2009, 9:23
Dobre,
We disagree.
I think you want to eliminate any possibility of cross-contamination of data. Better to be 100% certain than take chances, in my opinion . . .
Jono
PostPosted: October 12th, 2009, 9:36
Well, jono, as i wrote, a new disk is supposed to be clean.
But as we all know there are some people out there that try to be smart and sell old/refurb/tampered disks as new.
So, i agree, as a precaution wipe ALL disks before use.
Dobre
PostPosted: October 13th, 2009, 16:58
Neat feature in the Deepspar imagers I use, an option after the clone to erase all uncloned sectors on the target and set the HPA to match the patient.
I always do this to eliminate all possibilities of cross contamination.
PostPosted: October 14th, 2009, 18:54
I fill destination drives with a pattern. So it is safe and easy to locate unread parts if there are any...
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 98 guests
