 Post subject: Freezer Drive?
PostPosted: October 29th, 2009, 22:54
What do you think happened here?
This is the way it looked when I opened the top.
It was not opened before.
It will not rub off with a Q-tip.
Do you think this is a freezer drive?
 Post subject: Re: Freezer Drive?
PostPosted: October 29th, 2009, 23:37
Q-tip?
Are you serious?
www.datarecoveryne.com
PostPosted: October 30th, 2009, 0:07
I did the Q-tip just to see if it was light dust or burnt on.
It will not rub off.
I had no plans to recover it after I took a look at it.
Anybody want to give it a try?
PostPosted: October 30th, 2009, 1:09
Wow! I had one similar to that look a few months ago... Client said he researched it on the internet and put the drive in the freezer for an overnight. He told me the first 20 minutes of quick freeze didn't work, so he figured freezing the drive overnight would help...
PostPosted: October 30th, 2009, 3:51
Perhaps it would make a nice gallery shot of what can happen when you freeze your drive.
https://www.mjm.co.uk/
PostPosted: October 30th, 2009, 4:17
DRNJ, may i use that picture to put on my website ?
Thanks,
Dobre
Murphy was an optimist
PostPosted: October 30th, 2009, 6:46
I really don't think that was the result of being left in a freezer.
Looks like lubricant or some other type of contamination. I assume the PCB was perfect?
http://www.datasaversllc.com
PostPosted: October 30th, 2009, 8:16
What did the client say? Did they put it in the freezer or did the drive get submerged?
PostPosted: October 30th, 2009, 9:34
The pic is unclear but if it was a samsung recent drive, it can be the reaction of the platter lubrication coating to freezing and moisture (Samsung clearly states it). Of course, it is a partial game over.
PostPosted: October 30th, 2009, 16:26
It looks like regular massive media damage. There is some alive media left close to the spindle hub
PostPosted: October 30th, 2009, 16:43
yes, somebody can recover the last some LBA. :D
This is useful usually, at lest will get the boot sector copy. :mrgreen:
BTW:
I have this case in my gallery.
This is a hitachi drive.
http://adatmentes24.hu/hun/galeria_kepek/P1030195.JPG
http://adatmentes24.hu/hun/galeria_kepek/P1030197.JPG
If somebody interested about the entire series:
http://adatmentes24.hu/hun/?modul=kepgaleria-s2
All series:
Ps: Sorry, the translation is still in progress, maybe i will have time to finish it in this year...
Janos
PostPosted: October 31st, 2009, 0:13
This one came through a local PC repair shop. I did not talk directly to the customer. The customer was upset and wanted his drive back to send someplace else. There has been no contact since. Maybe one of you will see the drive soon. There were no signs of water damage. The PCB looked OK. No signs of water, grease or oil inside the drive. Just a fine coat of crash dust and platter damage which you can see. It was a Hitachi DeathStar IC35L120AVV207-0.
BLACKST’S Comment sounds interesting:
“it can be the reaction of the platter lubrication coating to freezing and moisture (Samsung clearly states it).”
Maybe Hitachi has a similar problem?
PostPosted: November 1st, 2009, 16:36
Uhm... the crash dust could go away with Q-tip (from inside HDA chamber), what I don't get is that kind of damage on the platter.
At this point, if it is not a samsung, I think it can have been BAKED rather than freezed (exposed to extreme temperature).
You can try yourself with a broken DeskStar... remove one platter and expose to heat to see if the behaviour is the same.
DO NOT put on microwave or you will have homemade fireworks-in-a-box :D
P.S. I can't see the picture clearly beacuse I am using my mobile... permanent vacation :D
PostPosted: November 4th, 2009, 11:05
Drives freeze all the time in shipping. They can be in trucks/trains for days at sub-zero temperatures and work fine once they warm up.
PostPosted: November 4th, 2009, 13:09
Sub zero maybe, but a 3 *** or 4 **** common freezer can be -20 , -25 deg. C. , there's a limit....
PostPosted: November 4th, 2009, 13:10
Plus there's a difference between gradually changing temperatures as in when it gets cold at night and abruptly warming up something from below freezing in terms of causing condensation.
PostPosted: November 5th, 2009, 14:53
Ah, I was talking F, not C. -20 or -25 deg. C (about -5 to -13 F) won't cause any sort of problem.
Edit: Woops, see my comment below. I thought we were talking about storage, not operation.
PostPosted: November 5th, 2009, 15:04
Woops, apologizes to you and BlackST.
I thought we were discussing storage temps, not operating temps.
Don't run hard drives below 5C (about 40F).
Users browsing this forum: Google [Bot] and 178 guests
