 Post subject: HITACHI HDS728080 PLAT 20
PostPosted: November 17th, 2009, 15:30
Hi to all,
Have this case that the disk dont spin and it dont have any ATA register.
Change the PCB with a equal one but with different PCB numbers and i can get ID and serial.
When i try to copy any sector with DE, i have a ECC reading error ?
Anyone knows which number is the TVS or FUSE , to repair the patient PCB.
ZeBong
" Россия еще раз"
 Post subject: Re: HITACHI HDS728080 PLAT 20
PostPosted: November 17th, 2009, 15:40
zebong u are not forgetting someting.. 8) like NVRAM?
PostPosted: November 17th, 2009, 18:05
Yes i know that, but what i notice in this was:
- when i change the PCB i could get ID, and read the modules !!!
is this possible without change the NvRam, normaly when i change PCB and dont change the nvram i can not get ID i have to change also Nvram.
Waiting for any comment if someone happen this.
ZeBong
" Россия еще раз"
PostPosted: November 17th, 2009, 18:11
if nv ram is not compatible i think disk goes into safe mode so therefore modules can be read. Swap NV Ram or try to rebuild NV RAM using UDMA.
PostPosted: November 17th, 2009, 18:46
Yes, as long as heads are good you can access SA, even with wrong NV-RAM. That's how Ace and SD rebuilt NV-RAM simply by rebuilding from SA. Run dynamic repair and you should be able to access data area. In some cases you have to set LBA too.
PostPosted: November 17th, 2009, 20:01
I am not facing with PLAT drives every day, but don't they store SA location in the NVRAM, as their other brothers do?
If so, it is not that probable that u can access the SA with a different NVRAM unless u set SA location before...
PostPosted: November 17th, 2009, 20:48
Pepe is right, PLAT stores the beginning of the SA location in the NVRAM. Not sure if SA location changes allot on the same model drive. I just did a PLAT yesterday and I was able to access SA with donor PCB, but the donor was from the same Raid 0 set and was 100% compatible and within 8 weeks of manufacturing date. Either way with PC3K UMDA or SD tool you should be able to easily repair this one :D
PostPosted: November 17th, 2009, 20:57
Then it seems PLAT do not change SA location that much :)
PostPosted: November 17th, 2009, 21:04
Sir Pepe,
I did WD2500JB last week also from Lacie RAID0 both drives where identical and had the same day of manufacturing and even the serial number was close. The rom was 100% compatible. It would be interesting to know how frequently adaptive information changes for the manufacturers. I know this probably changes often, but it would be interesting to know.
PostPosted: November 17th, 2009, 21:09
yes.... it would be interesting to see if MHAs are interchangeable... :D
Users browsing this forum: No registered users and 145 guests
