 Post subject: WD HDD Recovery 2% Formatted
PostPosted: November 21st, 2009, 21:09
I really screwed :shock: up and started formatting my WD HDD. It said it was 2% formatted when I realized it was the wrong drive. What are my options??? Is there any more info that you need to know??
 Post subject: Re: WD HDD Recovery 2% Formatted
PostPosted: November 21st, 2009, 21:34
Check your PM, I have a few suggestions
PostPosted: November 22nd, 2009, 1:39
Do not work on this drive
Clone it to another drive using another system
You might have to clone backwards on this one or you can try with Winhex on this
Then with a DR program such as RStudios or even winhex start to scan this drive
You have deleted the beginning of your drive now with the format and might have to do raw recovery to get back your data off this drive then rename your files.
Good luck
Iorana Haraharaini
PostPosted: November 22nd, 2009, 1:41
Image your data-loss drive to the same or bigger size hard drive!
Get another hard drive to install the OS!
Put your original data-loss drive away.
Connect your duplicate hard drive as a slave.
run any of the commercially available logical data recovery software and you should have your data back in a few hours to a half-day depend on how big your drive is.
Get Data Back as a key word on Google for the logical recovery tools!
Good Luck!!!
Users browsing this forum: Google [Bot] and 165 guests
