 Post subject: Toshiba MK1652GSX speed and writing problem
PostPosted: December 8th, 2009, 17:50
I have some problems about my hdd. I used to have windows vista but when I reached a 50 gb of usage it slowed down. now I use windows xp sp3 but still it is too slow. When I try to install something it writes too slow. I checked the speed with a program but can't understand anything. have you got any clue.
 Post subject: Re: Toshiba MK1652GSX speed and writing problem
PostPosted: December 8th, 2009, 20:27
I would bet the drive is switched to PIO mode, damn slow...
PostPosted: December 9th, 2009, 6:48
When I wasn't able to install the windows and saw a blue screen, I had changed the bios settings from AHIC mode to compatibilty mode. So I could install the windows şn compatibilty mode. But it is slower than ever. I tried to change into AHIC mode but when openning I see a blue screen at the beginning. What can I do? Is this a phsycal or a logical problem? Should I change my hard drive?
5400 rpm. ToshibaMK1652GSX
PostPosted: December 9th, 2009, 12:18
i would suggest replacing this disk. in my experience many toshiba drives go bad extremely fast once they begin to have bad sectors or getting simply slow (guessing weak heads).
Users browsing this forum: Google [Bot] and 156 guests
