 Post subject: Steps to diagnose a 'dead' Seagate 7200.10 ?
PostPosted: December 17th, 2009, 14:32
Obviously I am not a HDD Guru, I am merely an enduser seeking enough knowledge to have the proper repairs performed on my HDD. The guy at the computer shop was very dismissive and said I would have to send the drive to a laboratory for recovery and it would cost a few thousand dollars. This isn't acceptable to me since he didn't even look inside the computer (iMac)...
I am *not* expecting to become a professional for this one drive. Nor will I attempt to open the HDD in my home.
This drive seems to have died and I have no usable back-up. I'm kicking myself now... but I need to try to recover this data... if it is going to cost $1,000+ USD I am going to have to wait until I can save that money. But in the meantime I would like to diagnose the malfunction or at least eliminate some possibilities.
Can anyone give me a link to a walkthrough on diagnosis? I searched for such a thing on this forum and the one link that appeared to be relevant was broken...
The only information I have on the status of the drive is that it spins-and-clicks over and over.
edit* - Thank you in advance. Even if your only advice is to pay a pro to diagnose it! :) Lucas
 Post subject: Re: Steps to diagnose a 'dead' Seagate 7200.10 ?
PostPosted: December 17th, 2009, 14:40
It would help if you describe in detail what you was doing when it failed, what happened to it, what exactly is the drive doing when powered eg spinning, buzzing, clicking, normal sounds or completely dead. You will need to use your ears.
PostPosted: December 17th, 2009, 15:04
It could be a firmware failure or bad head(s) / damaged media.
You can't diagnose the FW problem without special gear. That same gear will also indicate if the heads have failed or not.
If you need & value your data, I wouldn't experiment with this drive.
Jono
http://www.datasaversllc.com
PostPosted: December 17th, 2009, 15:06
Lucas
The majority of the time this symptom is caused by bad heads and/or damaged media surfaces. Unfortunately for you, it will have to be looked at by a pro.
PostPosted: December 17th, 2009, 16:25
record the sound it is making for a few min and post it here.
PostPosted: December 17th, 2009, 16:40
Excellent idea. Here is a recording of about 30 seconds or so. The sound doesn't seem to change over time so I thought it prudent to make a shorter recording.
http://www.kellnerpm.com/seagatesound.mp3
PostPosted: December 17th, 2009, 16:42
I don't know what the computer was doing when it failed... It just wouldn't start up one morning...
Last edited by typicallucas on December 17th, 2009, 16:50, edited 1 time in total.
PostPosted: December 17th, 2009, 16:50
typicallucas wrote:
It didn't die while the computer was on. It just wouldn't start up one day...
Elaborate please...
It is impossible to determine a problem just by saying it wouldn't start one day. Its a same as if someone would say "My car wouldn't start, what is wrong with it?"
Describe every possible detail..., such as: It spins up, makes clicking noise, makes beeping sounds and etc.
www.datarecoveryne.com
PostPosted: December 17th, 2009, 16:51
I know, I apologize. I posted a recording of the sound it makes but it needs to be approved by a moderator before you can view it.
I could try to trick the forum into posting the link by adding spaces or changing the period to (dot) but being new to the forum I don't want to try any funny stuff and anger the forum gods.
Last edited by typicallucas on December 17th, 2009, 17:00, edited 1 time in total.
PostPosted: December 17th, 2009, 16:57
Here are more details, but they probably have more to do with OSX than the condition of the HDD.
After about 3 minutes the HDD stops making the clicking noise and on the screen of the computer it shows a folder which shows a question mark and an OSX logo.
About 5 minutes after that the case fans start spinning at what sounds like their maximum speed.
edit - 10 minutes later the fans are still going like hell. I'm going to turn it off because it sounds like a jet is taking off in my room...
Last edited by typicallucas on December 17th, 2009, 17:08, edited 1 time in total.
PostPosted: December 17th, 2009, 17:05
Ok, the forum wouldn't let me attach an mp3, but it would allow me to post it as a .zip archive.
seagatesound.zip [482.53 KiB]
Downloaded 313 times
PostPosted: December 17th, 2009, 17:10
heads or CE LOG error
or can not read servo
ZeBong
" Россия еще раз"
PostPosted: December 17th, 2009, 17:12
Is this something I can fix with a quick slap on the side of the case? Kidding!
PostPosted: December 17th, 2009, 17:14
no,
you will need expensive tools for that.
ZeBong
" Россия еще раз"
PostPosted: December 18th, 2009, 4:36
Any other ideas? or does Zebong pretty much have it covered? And is there a way I can eliminate any of those possibilities so I know better what the repair is going to entail?
PostPosted: December 18th, 2009, 9:48
No, its pretty much time to send it in.
PostPosted: December 19th, 2009, 6:07
250Gb $1000......seems so much. you can find out more reasonable
data recovery service[/b]
PostPosted: December 19th, 2009, 9:01
It depends on the condition of the platter. If it is badly scorched, $1000+ is not overpriced.
But of course a precise diagnosis done by an expert is highly recommended. Find someone on the forum in your area.
I think Jono might be fairly close, a few bucks, and the drive is there...
U might ask thatdellguy, I am quite sure he is also near.
PostPosted: December 19th, 2009, 14:16
thatdellguy is near LA and he is recommended to handle this case.
Users browsing this forum: No registered users and 129 guests
