 Post subject: BAD HEADS VS DIRTY HEADS
PostPosted: December 24th, 2009, 12:03
Hi to all,
Have this seagate momentus 5400.2 with this in terminal:
Interface task reset
4096k x 16 buffer detected
MERCURY - 1_Disk 3.06 05-
Buzz - 27-05 16:43
Head Mask FFFF - Switch to full int.
$Head Mask FFFF - Switch to full int.
Spin Ready
3.06 05-27-05 16:46
(P)PATA Reset
$Head Mask FFFF - Head Mask FFFF -
Look the heads at the microscope i have this
Anyone have good results in Cleaning the heads like this or just find a donor heads ?
ZeBong
" Россия еще раз"
 Post subject: Re: BAD HEADS VS DIRTY HEADS
PostPosted: December 24th, 2009, 12:08
First of all you should measure the MR sensor for judge it is worth a cleaning or not...
PostPosted: December 24th, 2009, 14:08
To me the heads do not look all that dirty, but then again it's hard to tell just by looking at them. Sometimes I have really good results with cleaning heads and sometimes I don't. it all depends. Sure you can try to clean the heads before sourcing for a donor drive, you can't really lose anything by doing so. On Seagate drives after giving the heads a special treatment I can often recover some data. If only certain files are needed this sometimes works well, but if you need a full image of the drive, the chances are slim.
I agree with Janos,
check MR sensor first.
Good luck!
PostPosted: December 24th, 2009, 14:31
What measurement readings can be expected from good heads in comparison to damaged or dirty ones?
PostPosted: December 24th, 2009, 16:14
The best if you can compare with donor drive. :P
Or with another head on the MHA wich is known good.
Anyway, a good MR is from 22-250 ohm, it depends on the head type.
The most of the longitudinar drives have 22-75 ohm, and the most perpendicular have 100-200 ohm.
Janos
Users browsing this forum: No registered users and 164 guests
