 Post subject: Sansung HD161HJ PROBLEM
PostPosted: January 4th, 2010, 8:39
Hello I have this in the terminal sansung HD model 161HJ/SRO hard disk seems to go into standby always busy more suggestions are welcome, I thank you
SPW 0000 NoLk
5V: 04940
SpnOk
spd: 0000 0000 0000
H: +00000
ADC: FFFD
DAC: 9D93
SK C: 00019AAC
ENG>SRV>
SvoTbl Loaded
CL B0B6 CM AC97 SL 31BE SM 34A4
BD
FdtTbl Loaded
 Post subject: Re: Sansung HD161HJ PROBLEM
PostPosted: January 4th, 2010, 10:40
Are you sure the pcb is original?
It seems that PCB is not native and not matching the FW on the platters.
PostPosted: January 4th, 2010, 11:15
Not Pepe the PCB is ok, tested PCBs in other hard disk and it worked perfectly, any help is welcome. thaks
PostPosted: January 4th, 2010, 11:35
I did not say it is damaged, just that it might be not the original one....
PostPosted: January 5th, 2010, 0:02
don't understand what pep mention at all 8) and have you try hot swap?
data recovery service[/b]
Users browsing this forum: No registered users and 129 guests
