 Post subject: ST3250620A FW:3.AAD - Stops to initialize
PostPosted: January 6th, 2010, 6:13
Dears,
I have a problem with ST3250620A (FW:3.AAD).
PC3000 correctly shows the drive parameters during detection but after it I cannot access data.
The terminal shows that some sector could not be read. It tries to read that sector continuesly.
I try to stop the process with CTRL+Z, and when I put CTRL+C (reload cert code) drive starts reading data through 3-4 secs. After it the process starts from the beginning.
Unfortunately I cannot find suitable ldr for that drive, so can you help me with it?
I need ldr or some tricks to get data.
I will be very appreciated for help.
Regards,
Rafael
Terminal data:
4096k x 32 DRAM
GALAXY2D - 1_Disk S-6B 06-29-06_12:30
HM SFI
(P)PATA Reset
Master
AT Er 00 Nwt Er 37 RdWr 004f0.00.0053
ATA St d0 Er 00 Op 24 e, 16148572,0100 0100 0000
Niwot: 97f29ff7 b6 97f29ff7.3.e29 0000 005f 0000 0001
DiskAccess ReadSector EC=43 at 0004f0.00.0053
CE Log ErrCode=37 LBA=53f8a6 Type=5 Add To Pending 53f8a6
AT Er 00 Nwt Er 37 RdWr 004f0.00.0063
ATA St d0 Er 00 Op 24 e, 16148573,0100 0100 0000
Niwot: 97f29ff7 b6 97f29ff7.3.e3a 0000 005f 0000 0001
DiskAccess ReadSector EC=43 at 0004f0.00.0063
CE Log ErrCode=37 LBA=53f8b6 Type=5 Add To Pending 53f8b6
AT Er 00 Nwt Er 37 RdWr 004f0.00.0071
Niwot: 9ff79ff7 b6 9ff79ff7.3.e3a 0000 005f 0000 0001
DiskAccess ReadSector EC=43 at 0004f0.00.0071
CE Log ErrCode=37 LBA=53f8c4 Type=5 Add To Pending 53f8c4
AT Er 00 Nwt Er 37 RdWr 004f0.00.009a
ATA St d0 Er 00 Op 24 e, 16148574,0100 0100 0000
Niwot: 97f29ff7 b6 97f29ff7.3.ffd 0000 005f 0000 0001
DiskAccess ReadSector EC=43 at 0004f0.00.009a
CE Log ErrCode=37 LBA=53f8ed Type=5 Add To Pending 53f8ed
AT Er 00 Nwt Er 37 RdWr 004f0.00.01c3
Niwot: 9ff79ff7 b6 9ff79ff7.3.ffd 0000 005f 0000 0001
DiskAccess ReadSector EC=43 at 0004f0.00.01c3
CE Log ErrCode=37 LBA=53fa16 Type=5 Add To Pending 53fa16
CorrectWriteStart
AT Er 00 Nwt Er 22 RdWr 004f0.00.01c0
Niwot: 0053f8ee 14 0053f8ee.2.010 0128 3fff 0128 0000
CorrectWriteStart
Niwot: 0053fa13 14 0053fa13.2.010 0003 4124 0128 0000
 Post subject: Re: ST3250620A FW:3.AAD - Stops to initialize
PostPosted: January 6th, 2010, 6:57
you should use the seagate utility options to clone that disk.
add to pending BUG
ZeBong
" Россия еще раз"
PostPosted: January 6th, 2010, 18:45
Yeah, you have "the tool" better use it as zobong said.
And why you ask for a loader, loader have nothing common with your case.
DataRecovery.bg
Users browsing this forum: No registered users and 112 guests
