 Post subject: What is the position of the heads when sata cable isnt in?
PostPosted: January 10th, 2010, 16:34
If i connect the power and not the sata what do the heads do?
do they move at all?
only at the start?
do they stay parked until sata is in?
 Post subject: Re: What is the position of the heads when sata cable isnt in?
PostPosted: January 10th, 2010, 17:40
As you have described does the motor spin up?
Depending on the drive make and model, the jumper position might determine if the drive will spin up with or without a signal from the motherboard.
PostPosted: January 10th, 2010, 19:38
Typically the drive will still init normally but I have seen some Hitachi laptop drives that don't do anything until SATA is plugged.
Users browsing this forum: No registered users and 134 guests
