 Post subject: PCB are compatible for U12 swap?
PostPosted: January 18th, 2010, 17:22
My original HDD is:
WESTERN DIGITAL WD800
MDL: WD800JD-75LSA0
DCM: DSBHCTJCH
model PCB: 2060-701335-A00
Donor:
MDL: WD800JD-00MSA1
DCM: HSBANTJCA
model PCB: 2061-701335-E00
Are PCB compatible for swap U12? Original PCB no sound, nothing.
Carlos
 Post subject: Re: PCB are compatible for U12 swap?
PostPosted: January 18th, 2010, 17:27
yes
PostPosted: January 18th, 2010, 17:38
Thank you!!!
PostPosted: January 21st, 2010, 12:22
I desoldering ROM U12 from patient PCB and soldering to Donor PCB and when i connect hdd make tac tac sound. :(
PostPosted: January 21st, 2010, 14:09
Double check your soldering job.
PostPosted: January 22nd, 2010, 22:57
are you sure head or firmware are ok? 8)
data recovery service[/b]
PostPosted: January 27th, 2010, 15:35
The ROM is OK
pacient PCB is 003 REV A
Donor PCB 005 REV B
PostPosted: January 27th, 2010, 21:19
probably preamp is gone.
PostPosted: January 28th, 2010, 6:43
You should try again with a diffrent donor PCB (003), maybe you still have a last chance.
Users browsing this forum: Google [Bot] and 138 guests
