 Post subject: How do I update the hard drive's firmware?
PostPosted: February 3rd, 2010, 11:09
Hi all,
The site offers a firmware update for seagate hard disk
http://files.hddguru.com/download/Firmw ... s/Seagate/
(The one on the bottom - 8h_SD1A.zip )
How do I use it?
How to update the firmware of the wanted hard drive?
Thank you very much!
 Post subject: Re: How do I update the hard drive's firmware?
PostPosted: February 3rd, 2010, 13:59
The drive has to be in full working order to apply the firmware.
It's a firmware UPDATE, not a repair.
PostPosted: February 3rd, 2010, 16:00
I would advise you to avoid HDD Guru firmware downloads.
Instead, the most recent firmware updates are available from Seagate's web site:
http://forums.seagate.com/stx/board/mes ... ad.id=8968
There are Windows versions and CD ISO (FreeDOS) versions.
If your drive is suffering from the BSY bug, let us know.
PostPosted: February 3rd, 2010, 16:24
Why don't you contact Seagate support. They should be able to help you.
PostPosted: February 4th, 2010, 3:25
Thanks for the quick response.
How do I know if my problem is the "bsy bug"?
thank you guys!
PostPosted: February 4th, 2010, 5:21
Just connect it to your PC and see what will happen.
If detected normally ( with real capacity ) then your drive is (approx.) working fine, if not detected or detected but with 0MB then you have to fix your drive first then update the firmware.
Users browsing this forum: No registered users and 157 guests
