 Post subject: SEAGATE HARD DRIVE FROZEN password LOCKED
PostPosted: February 2nd, 2010, 3:19
so one of my family decided to use a program to delete there hard drive.
but as they where doing the reformat the power went of in the house.
the drive in qeastion is a seagate ST9808211A MOMENTUS
it has got what it says a frozen password locked so i can not unlock it with pc3000
anyone know which pin it is to short out
so i can unlock this drive for them
thank you
 Post subject: Re: SEAGATE HARD DRIVE FROZEN password LOCKED
PostPosted: February 2nd, 2010, 19:41
ok i found out that they used a program on hirens bootdisk
and the drive program frozen the hard drive.
so you can not delete it
PostPosted: February 4th, 2010, 5:12
There should be a solution still...
PostPosted: February 4th, 2010, 5:17
I agree, password should still be possible to remove. Maybe problem is not ATA lock, but other problems causing problems with identification/interface which reports itself as ATA lock? I have seen some cases in the past where bad interface or bad PCB causes bad ID and ATA lock appears to be present....
PostPosted: February 4th, 2010, 6:10
If HDDerase v4 was used then you might want to have a read of the documentation readme file.
Users browsing this forum: No registered users and 154 guests
